F9DXER
Came across this while doing a charter flight into CYYZ - acft was using Txy K.
From CYYZ 10-9 page - Ball Note #2
"Twy K is uncontrolled and is restricted to acft with a wingspan of 135' (41.15m) (B757W) or less and an Aircraft Load Rating of 9.0 or less. Other aircraft may be authorized with prior approval from OPS."
I have never heard of an Aircraft Load Rating. (ALR)
A quick search gave this table.
Aircraft Load Rating (ALR)
Number expressing the relative structural loading effect of an aircraft on a pavement. ALRs are expressed on a scale from 1 (least demanding aircraft) to 12 (most demanding aircraft). ALRs have been assigned to present-day aircraft at their maximum and minimum operating weights and at a specific tire pressure. The ALR should not exceed the pavement load rating (PLR) for unrestricted aircraft operations. The ALR system for ranking aircraft in terms of their pavement-strength requirements is used exclusively in Canada. For the international reporting of aircraft pavement-strength requirements, the ICAO ACN (aircraft classification number) code is used.
No need to thank me!
