NewsBot
Administrator
Bombardier London, England United Kingdom, International:<BR /><strong>BOMBARDIER</strong><br /><br />At Bombardier Aerospace, our employees work together to evolve mobility worldwide - one good idea at a time. If you have a good idea, we’ll provide the environment where it will thrive and grow into a great product or customer experience. Your ideas are our fuel.<br /><br />Bombardier’s Business Aircraft London Service Centre in Biggin Hill is part of an award winning network and is the flagship of Bombardier’s European operation. This Base and Line Maintenance Centre is the fastest-growing Service Centre in Europe and the largest Business Aircraft OEM in the UK. The facility has the capabilities to perform an array of maintenance checks, modifications and upgrades all from this site. Only 14 miles from London, Bombardier’s Biggin Hill Service Centre is ideally located to support operators in the UK region and beyond.<br /><br />The facility is actively expanding and has an exciting opportunity available for experienced B1, B2 and C Aircraft Engineers based at the London Biggin Hill Airport, United Kingdom.<br /><br /><br />In your role as a B1/B2 Line Maintenance Certifying Technician you will,<br /><br /> <br />• Troubleshoot, repair, inspect and perform maintenance on customer aircraft<br />• Perform and document all work performed per appropriate manuals and regulations as required<br />• Train, coach and support other employees<br />• Perform complete engine runs as required<br />• Perform complex repairs on aircraft systems<br />• Supervise Mechanics when carrying out maintenance tasks, and determine that relevant tasks or inspections have been carried out to the required standard<br />• Release line maintenance tasks that are performed by him-/herself or under his supervision for which he/she is trained and authorized<br />• Sign off base maintenance tasks that are performed by him-/herself or under his/her supervision, in support of Certifying Staff Category C<br />• Perform maintenance at off-site locations<br />• Assist when providing time estimates<br /><br />In your role as a B1/B2 and C Base Maintenance Certifying Engineer you will,<br /><br /> <br />• Identify constraints and pro-actively prepare maintenance projects (e.g. organizing work stations)<br />• Verify if Mechanics and B2 Support Staff assigned (‘crew’ are qualified to perform the task(s)<br />• Ensure Cat C tasks are delegated to other Cat C or senior B2 when not available - delegating duties does not relieve the Cat C of the overall responsibility for the crew<br />• Understand that when also carrying out maintenance tasks, such tasks should not be undertaken when incompatible with the project-management responsibilities<br />• Prioritize work, and coordinate/assign daily work plan to the crew<br />• Ensure performed tasks are in accordance with Bombardiers Maintenance Organization Procedures<br />• Ensure that all required maintenance tasks are carried out, that all work accomplished is airworthy and, where not completed, that deferrals will be reported to the operator<br />• Provide time estimates and monitor efficiency to ensure that scheduled man-hours are not exceeded, and coordinate overtime requirements with the Project Manager<br />• Ensure crew maintains good housekeeping practices<br />• Ensure all task-handovers are done at the end of the shift, as well as the shift-handover<br />• Release aircraft and authorized, by signing the Certificate of Release to Service after base maintenance
Continue reading...
Continue reading...
