Thrust vectoring and super-cruise??
Close! lmao Some of the improvements are in aerodynamics and weights. A "performance improvement package" (the PIP) and one PIP is for the airplane’s new
General Electric GEnx-2B turbofans. It will include a new low-pressure turbine design, redesigned high-pressure compressor airfoils, as well as an “upgraded” combustor and improved high-pressure turbine aerodynamics, and would gain certification in the second quarter of 2013, according to GE’s schedules.
Also, another update to the FMC from Honeywell, an improved navigational performance (RNP), and that allows for just a little more efficient approaches and some other functionality improvements (3rd upgrade I believe to the FMC), a little more opportunity for operational advantages and also a software solution to certify tail fuel tanks that were meant to hold another 3,300 gallons of jet-A in the Intercontinental. Computer simulation testing showed that the airplane would experience some minor structural flutter in the event of a failure of the R3 under-wing, mid-spar strut-to-wing fitting, one of six connecting the outboard engines to the wing, when the tanks held more than 15 percent of their capacity. As a result, Boeing had to decommission the fuel tanks to gain certification of the variant last December. The tanks will raise the 747-8’s total fuel capacity to 64,055 gallons, extending its range from roughly 7,650 to 8,000 nm. (The 747-8 Freighter does not use those tanks).
Boeing plans to fit a single instrumented flight test airplane with the complete PIP, the FMC improvements, the engine modifications and the tail tank reactivation for simultaneous certification before the end of next year. The engine PIP alone should bring performance to within 1% of specification, while aerodynamic upgrades and weight reductions will account for much of the balance. Designed to operate 15% more efficiently than its GE-powered 747-400, the 747-8 relies largely on a new supercritical wing for its performance benefits. The engine, meanwhile, represents fifth-generation technology and resists deterioration over time far better than its precursors, translating into better midlife performance and less cost/maintenance issues.
Next up......enemy radar detection, deflect, jam or offset radar-controlled approaching missile systems, flares and chaff. lol Seriously, I think the 8 would be a super choice for AF One.
