drunkenbeagle
Gang Member
No. VFR or IFR or not, while you can get to that exact point in space, you're not doing it with panel installed, certified navigation equipment on board the aircraft. Without proper tolerance certification, accepting something as precise as 'direct to a FIX' becomes an approximation at least to some degree.
Accepting a direct routing to a fix with uncertified equipment sounds like it would walk all over a few FARs.
Okay, lets define "direct" (from the Pilot Controller Glossary)
DIRECT− Straight line flight between two navigational
aids, fixes, points, or any combination thereof.
When used by pilots in describing off-airway routes,
points defining direct route segments become compulsory
reporting points unless the aircraft is under
radar contact.
Can I accept a DIRECT clearance VFR? I do almost every time I enter a Bravo. (which is a fairly often). Can I be cleared to something direct visually? Sure, any time I fly a visual IAP. The North Bay Visual RWY 17 @ KPIE is an example. Direct does not imply RNAV/GPS.
Back to the definition - Direct simply mean a straight line between any combination of navaids, fixes, or points. My PPL cross countries way back when (pre-GPS) were not on airways, yet had "direct" segments between visually identified landmarks. Those legs were straight line, and therefore, direct. I filed a flight plan, so presumably FSS was okay with it.
