germb747
Did he have spikey hair, an ipod and a backpack?
No, but she was actually pretty good looking!
Great gouge. Also, not sure if this has been mentioned already, but don't put too much stock in your civilian flight experience. I don't know for sure if the AF cares about this on applications, but I know the USN/USMC could care less if you have 100 hrs, 10000 hrs, or 0 hours.....it won't help out your package at all.
I'm in agreement with the "lots of civil time doesn't help" argument. This is especially true in the T-38 track (can't speak to how it goes over in the TONErs).
What is it exactly that makes T-38's so tough compared to T-6's? The high speeds? Handling qualities? Everything?
There is only about 30 minutes of fuel available for area work, and with long lists of exercises and maneuvers to be performed, students have to plan out their maneuver entry/exit altitudes and airspeeds carefully to be efficient (that fuel goes FAST).
The handling is significantly different, too, as well as how the aircraft is flown. Swept wing jets climb, descend, and turn differently in terms of stick and throttle application than a straight-wing turboprop. In flight, that primarily manifests itself in things like turns requiring significant back pressure on the stick and/or no rudder application. Lead points for climbs and turns, are different. More attention has to be paid to throttle position, as the airplane accelerates like greased lightning. The landing pattern performance differs, the landing/flare picture differs, etc.
Set your lift vector and pull.......the unwritten #4 DACM rule for the Hog after Lose Sight, Lose Fight; Maneuver in relation to the Bandit; and Nose position vs Energy.
 Definitely some of the most fun I have had in an airplane yet though
