Ralgha
Logging IFR- PF (pilot flying) logs the actual time
So you're saying that the PNF is not operating the airplane? What the hell are they there for then?
Night: All flight time which occured from 1 hour after sunset to 1 hour before sunrise.
:yeahthat:
IMC is a condition of flight. It is not special bonus time. The SIC also logs IMC when they go through it, regardless of whose leg it is.
Saying they shouldn't is akin to saying the SIC shouldn't log night hours or shouldn't log total time. It doesn't make sense.
I log a hold if it was my leg and we completed one full circuit in the holding pattern, VMC or IMC.
I don't know how you could even do a "visual hold", the very nature of the maneuver requires you to use instruments, even in CAVOK. With that said, I log maybe half a dozen holds per year, if that.
For approaches, I log it if IMC was encountered between the FAF and DH/MAP and it was my leg. I don't end up logging many approaches either.
IMC: log it only if it is my leg. This has been discussed at length on this forum. A year or two ago I went back and retroactively deleted half of my actual time to reflect this.
http://www.logshare.com/log.jsp?email=ehmassey@gmail.com
Maybe there is some confusion here by either myself, or others on this board. Per FAR 61.51G and FAR61.57G3 YOU must be the manipulator of controls and be operating the aircraft be reference to instruments.
Maybe there is some confusion here by either myself, or others on this board. Per FAR 61.51G and FAR61.57G3 YOU must be the manipulator of controls and be operating the aircraft be reference to instruments. On legs that I am PF (Pilot Flying) I am doing just that- flying the plane. On legs where I am PNF (Pilot NOT Flying) I am taking care of pretty much everything other than actually flying the plane- ATC, dispatch, checklists, prepare the approach, raise gear/falps, etc. If you are justifying the fact that while flying in IMC as PNF one can log the IMC time, you would also have to explain the same rationale to say you can log every takeoff and landing. I do not see how you can do such a thing. I have asked an FAA person (called the MEM FSDO) in addition to reading the regs and was told that only the time where you are PF you can log the IMC/Appr/Landing. As PNF or Pilot monitoring you do not log anything more than the appropriate PIC/SIC requirement columns. These would include TT, SIC or PIC, XC, multi, night (if applicable) and any other generic column appropriate (such as a Jet or turbine column).
This question was about holds and the FSDO said to log the holds if I am trying to keep IFR currency per FAR61.57, even though I am covered under part 121 flying for part 121 flying under the requirements of the appropriate annual/bi-annual PC. They really didn't have an answer/clarification on the question of who logs (PF/PNF) a hold, just that it can be logged for currency.
Hope that helps for those who search. As always your logbook is YOURS and as long as you can explain things you are covered. I log only IMC time where I am the PF, log only the TO and LND that I perform as PF, and only approaches that I fly be reference to instruments per the FAR's (I use actual at or beyond the FAF as a point). Night, TT, Jet, Multi,XC, and SIC/PIC (as appropriate) are logged every leg regardless of PNF or PF status.
FAR61.51 said:(g) Logging instrument flight time. (1) A person may log instrument time only for that flight time when the person operates the aircraft solely by reference to instruments under actual or simulated instrument flight conditions.
FAR61.57 said:(c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has:
(1) For the purpose of obtaining instrument experience in an aircraft (other than a glider), performed and logged under actual or simulated instrument conditions, either in flight in the appropriate category of aircraft for the instrument privileges sought or in a flight simulator or flight training device that is representative of the aircraft category for the instrument privileges sought—
(i) At least six instrument approaches;
(ii) Holding procedures; and
(iii) Intercepting and tracking courses through the use of navigation systems.
FAR61.57 said:(a) General experience. (1) Except as provided in paragraph (e) of this section, no person may act as a pilot in command of an aircraft carrying passengers or of an aircraft certificated for more than one pilot flight crewmember unless that person has made at least three takeoffs and three landings within the preceding 90 days, and—
(i) The person acted as the sole manipulator of the flight controls; and
I guess we agree to disagree on logging holds.
Damn you for getting it back on topic!
