tgrayson
Where do I look to find this? I can't find it in any books...
Because it doesn't exist.
No, that's silly. The protected area for the PT is based on the fix designated for the PT, which is the NDB in this case. The purpose of the protected area is to allow for the maneuvering to get yourself turned around and this includes the entry. The PT is protected on all sides of the NDB. You can find diagrams of the protected area in the Instrument Procedures Handbook.
He's right about that. That does not depict the protected area for the PT. (It isn't circular.)
That sentence comes from TERPS, which are instructions towards the approach designer, not the pilot. The designer determines when it's necessary to reverse direction.
Understood, but if you learn the proper methodology of determining the truth, you can run rings around these guys who pick up info sitting around the pilot lounge, know what I mean? You made a good start by referring to the AIM, rather than taking what the DPE said at face value. Keep it up.
Here, read this and you'll know more about the subject than any pilot you'll ever fly with:
http://www.terps.com/ifrr/jul96.pdf
find something else to take me to a higher level of understanding instrument procedures. Recomendations (other than the TERPS manual)?
done a TON of homework on this. Is that primarily because of your issue with the approach into OLV
Let me give you an example of how our assumptions can be dangerous. I've posted the attached approach before, but it was a year or so ago and you might not have seen it. This approach was at my home airport, and the final approach course crossed underneath the approach to 27 at Memphis. The clearance we'd get when shooting the approach was typically:Turn left heading 210, maintain 2,500 until established on the localizer, cleared localizer 18 Olive Branch.The question is, when can I descend down to 2,000 feet? Here's the approach:
After passing mandd I would say, because you're not even really on the approach until then. But correct me if I'm wrong.
You're right, but most people miss that. Part of the problem is that ATC tends to use "until established on the localizer", which *seems* to contain implicit permission to step down once the needle centers. However, ATC is not supposed to use that language when the vector will not, in fact, establish the aircraft on a published segment. They should have been saying something like "cross MANDD at or above 2,500, cleared localizer 18". I rarely got that, however.
I went all through my instrument training without seeing the significance of it, until I saw a discussion by Wally Roberts, chairman of the ALPA TERPS committee, saying they had convinced the FAA to get rid of this type of approach.
Agreed. Must be an engineering thing... that's what I did before all this flying business came up. I'm still trying to convince some instructors that using the law of sines is perfectly legit in flying direct without GPS... cheap RNAV. Still unsuccessful.
Anyway, people would come bombing out of the flight levels, hit the 12DME arc and start around for Kuskm and begin a descent to 1800, you had to watch out for that.
Technically dead reckoning is legit for IFR
You mean prior to reaching *published* DME arc?
No, they wouldn't be cleared for the approach, but they'd start down anyway, well, yes, they'd do that too, but only in some strange circumstances where we were approaching from the south.
Irrelevant. Prudent (though unnecessary) to tell them you're doing the PT, though, since they have clueless pilots turning directly in.
ATC never cleared me for the approach, just told me to expect it, so we entered the hold. Approach then went into a rant about other airplanes in the airspace and not clearing us to enter the hold...I've just learned to take an extra transmission and verify everyone's intentions / expectations.
tgrayson, does FAA have electronic copy of TERP?I promised my DPE to read this and would like to keep my words.
