Checkride in two weeks.
N8081G
Going for my multi-commercial two weeks. I'll be doing it with the Piper Seneca. Any tips, suggesstions? DOs and DON'Ts? Please fill me in.
Thanks.:nana2:
Have fun and stay relaxed. Make sure you know how to use your E6B and that you know all the stuff from your private pilot checkride. Oh yeah.... read the PTS and go through the oral study guide.
Well, you have at least a couple of checkrides under your belt already, so you kind of know how it goes. I'm glad you posted that your checkride is in two weeks (as opposed to two days), because at least it shows you're putting thought into being well prepared. Just relax and do the best you can, use your checklist, be extra cautious, be well rested and fed when you show up, and have all your ducks in a row when you meet the examiner (check made out for examiner's fee, 8710 typed out neatly and correctly, checked weather/NOTAMS, figured weight and balance/performance data, have aircraft logbooks/paperwork ready with appropriate inspections tagged, and be able to nail the first 5-10 minutes of your oral to convince him you know what you're talking about so you can speed it along)--you have to set the right tone (passing a checkride is as much a phychological game with the examiner as it is an objective look at your ability, so first impressions count). I really liked the ASA "oral exam guides" as a review; I don't think I was asked a question not pertaining to the specific aircraft itself that wasn't straight out of that guide. Obviously, have a solid understanding of Vmc and single-engine stuff. If this is also your initial commercial, make sure you can explain your privileges/limitations with regard to holding out to the public and the concept behind a commercial operating certificate. That's just a few things off the top of my head. Good luck!
Two don't for ya. When the examiner kills one engine, make sure you feather the right one. Second doing the VMC demo make sure to keep an eye on the airspeed and don't press the wrong rudder. Overall should be very simple.
Don't forget the basics, like sectional chart stuff and airspace/weather minimums (if it's an initial commercial).
Thanks for the advice/tips.
This is my inital commercial. I started training back in 2006, was off and on from then until now mainly because i am in college (about to get my degree in december) and lack of money. However, when i was broke i got all the ground work out of the way e.g. the writtens and such. I also attended FlightSafety for a semester which gave me an aircraft dispatcher's certificate and twelve college credits as well..can't complain at all!:D
After getting my commercial, both multi and single engine addon i plan to get my CFIs and MEI sometime early next year and start teaching. It'll be too much to study for those orals while fulltime in college and also with a fulltime job. Anyways, sorry for going a bit off topic but i just wanted to share my journey so far.
My only main concern for the checkride is crosswind landings. It is sorta difficult to do in the Seneca, especially since i am still a low time pilot and hopefully on that day the winds will cooperate with me. The manuveurs themselves aren't that hard.
A crosswind landing is the same in a C-172 as it is in a Seneca as it is in a C-5 Galaxy, I've flown all three ;). Aileron to stop the drift, and rudder to align with the centerline. If it's bothering you now, you still have a couple of weeks to get comfortable with it--demand the extra practice if you want/need it.
That is true. The same technique applies to all airplanes but one thing i need to consider is that the separation between the props and the ground is only about 1 foot on the seneca. It is pretty easy to get a prop strike when landing on a crosswind if not done correctly. In the POH, the maximum x-wind component for the seneca is 15kts. Lower than the warrior which is 17kts. The seneca is also a pretty "nose heavy" airplane and if not trimmed correctly for landing, well you know the rest!:buck: I do plan to go up alteast two to three more times before my ride so i should be fine.
Clint says it best: "A man's got to know his limitations".
That bit of advice is good for any checkride.
...and no matter what anybody says, when the examiner says "Hey, nice steep turns, how about some stalls?"
Don't look over and say "Sure....Hold my beer and watch this":bandit:
I have a little, very little, Seneca time. However, germ is right on.
If you fly the plane within the published XWind limits, you won't strike the prop as long as you're easy on the controls. Especially if it has the interconnect for the rudder and ailerons.
Whats your limit Doug?
No limits, dawg! :)
Nah, just things that are found in your limitations section of your POH (PRM, POM for airline guys).
During the engine out stuff Fly the plane first and don't forget the Zero Side Slip! Then start running through your identify and verify.
1. Maintain Aircraft Control
2. Analyze the situation and take the proper action.
3. Land as soon as conditions permit
Man, it's been 5 years since I've flown a light twin! But it got nailed into me, so let's see if I remember it: :D
Airspeed (blue line/radial)
Mixture
Prop
Throttles
Gear Up
Flaps Up
Identify (dead foot, dead engine)
Verify
Feather
Bank angle (5 degrees into the good engine)
Cowl Flaps Closed
Checklist/Clean Up
(Always reference a checklist after you've done memory items, when you're stablized at a safe altitude and it's safe to do so)
Did I get 'em all? :nana2:
(at any rate, follow the procedures in your POH)
Or at Riddle it was, and I sadly still remember, control power drag identify verify troubleshoot feather.
Aye! Freaking "Johnny La Fever" drilled that into my brain.
sounds alot better than stall spin crash burn die :D
yea, I guess I forgot the 'troubleshoot' part, which would probably direct you to get the boost pumps on or otherwise try to get the engine back before feathering it if there's an obvious cause. Needless to say, I'd need a thorough checkout before I ever went back to flying light twins. :p
