A crosswind landing is the same in a C-172 as it is in a Seneca as it is in a C-5 Galaxy, I've flown all three. Aileron to stop the drift, and rudder to align with the centerline. If it's bothering you now, you still have a couple of weeks to get comfortable with it--demand the extra practice if you want/need it.
do know ALL your v-speeds
Clint says it best: "A man's got to know his limitations".
That bit of advice is good for any checkride.
That is true. The same technique applies to all airplanes but one thing i need to consider is that the separation between the props and the ground is only about 1 foot on the seneca. It is pretty easy to get a prop strike when landing on a crosswind if not done correctly. In the POH, the maximum x-wind component for the seneca is 15kts. Lower than the warrior which is 17kts. The seneca is also a pretty "nose heavy" airplane and if not trimmed correctly for landing, well you know the rest!:buck: I do plan to go up alteast two to three more times before my ride so i should be fine.
Whats your limit Doug?
Or at Riddle it was, and I sadly still remember, control power drag identify verify troubleshoot feather.
Aye! Freaking "Johnny La Fever" drilled that into my brain.
