Prino
no...approach does the sequencing and then hands you off to towerDo some act like D's meaning approach will just say enter at a certain point in the pattern then contact the tower when doing so?
However, regardless of the lack of a regulation I will continue to report midfield if in the pattern if asked to or not.
And if he/she doesn't, a simple "confirm Cessna 123 is cleared to land?" on base leg (or even final) will do.
However, regardless of the lack of a regulation I will continue to report midfield if in the pattern if asked to or not. I prefer to ask for clearance to land before I turn to base.
Bad call dude, sorry to join in on the bandwagon, cuz I know it sucks to get pelted on a forum, but look, there are going to be a hundred times that you land at a place with a straight in, then you're not going to have a chance to turn base. Or you may get something strange like "Cessna 123AB, Cancel Landing clearance, fly through final then make a right 270 to enter a left downwind for landing runway 07." The problem with doing something like reporting when there is no need to report is not only that it clutters up a typically congested freq, it also shows to everyone else that you don't know what you're doing. The best way to learn how to talk on the radio, and function in that environment is to listen to how the pros do it, then do it that way.
You can listen to the student pilots talk and you can tell exactly their experience level. "Uhh, Cessna 123AB is at AeroTech, with information whiskey, I'd like to taxi to runway 25 for a shipcreek departure with an altitude deviation." Good god that was verbose. All the commercial operators have it short and concise "Ground, Spernaks 38, at the ramp with alpha, ship creek, deviation." Think that way with yourself. Just be short and concise, don't clutter things up, or muddy the waters, its poor technique, and you'll look like an amateur. And when you look like an amateur (or sound like one) the controllers will treat you as such. Be professional.
The key to this is to be flexible, and to be listening to what's going on in the pattern around you.
Unless the controller tells you to make "closed traffic," you should be reporting all legs of the traffic pattern.
Tower Manager, and he informed me that pilots should fly a normal pattern with common sense
Ha, I don't mind people jumping all over me on a forum...its a forum. I still have much learning to do and would not be learning this if I did not open my mouth. I would rather it here than screwing up in the air. I guess I am just showing my inexperience, which is fine, because I am inexperienced. I have limited controlled field work. The field I fly at always requests a mid field report when doing pattern work. They and other airports I flew into with a tower have requested a position report when entering the pattern at a specific point. "Cessna 123 enter left base for 24 report 3 miles." "Cessna 123 left base 3 miles full stop 24" But, that is probably because I sound like a student.
Its funny, the student call to ground for taxi instructions is exactly how I was taught to talk. I have shortened it up but I am sure I still sound like a newb pilot.
Don't turn crosswind at an airforce field without getting cleared closed traffic or crosswind..... they get peeeeved!? Where is that little nugget of info in the FAR/AIM?
Don't turn crosswind at an airforce field without getting cleared closed traffic or crosswind..... they get peeeeved!anic:
If you are on downwind and hear the controller talking to a bunch of airplanes for the runway you are also planning on landing on, and the controller has not gotten to you yet...don't turn base. Is it a "rule"? No. It's common sense.
