MrFent
for those of you who used the practice software and took the test already.. i was wondering how you personally did on the practice software specifically the lettler factory portion.
I thought the lettery factory was a LOT easier on the AT-SAT. There was only 1 type of letter per belt. (the A's came only down belt 1, the B's down belt 2, etc) Plus you don't have to click on the actual letter & drag it to the box. You can click once anywhere on the belt & it will select the letter closest to the end, then you just click one on the box. Same thing when you place a box from the storage area, you just click it & it will automatically go to the empty loading area space. With the practice test, there were tons of letters spilling on to the floor, but with the real thing, I didn't drop one. They seemed to supply you with the ones you need to fill up each box before more of the same letters arrive. All of this will be explained in the directions, just be sure to read them very well & you will be fine.
