GnW
How long does it take to check out on a position?
At a larger facility. Say you need to check out on 5 RADAR positions to hit CPC at an 11 or 12 facility. How much "scope time" do you generally get to certify on a position? If you're making improvements and are almost there, do you get some leeway or is it a cut-and-dry "you're fired" if you can't certify in the maximum allotted time?
It would seem, to me, that if someone is improving and has a couple positions under their belt that they would be given some extra time to certify rather than starting over with a fresh body? But that probably makes too much sense for the FAA and isnt the case :whatever:
