kellwolf
Piece of Trash
Sim 4 - aka Mountain Flying for dummies
Start out on the runway in Helena, MT, 52,000 lbs and it's 25C outside. Which means the airplane is gonna climb even worse than it normally does. Takeoff roll, and lose the left engine at V1. Now, Helena is basically in the bottom of a fishbowl with mountains forming the sides, so we have a company procedure for engine out climbs. So, we start flying that procedure while doing the SE takeoff profile. And lemme tell ya, we had PLENTY of time to make the calls. This thing climbs like a DOG when it's heavy, hot and single engine. Finish up the company procedure and get repositioned to FL370.
Now it's time for some of the fun stuff. Jet upset, unusual attitudes, mach buffet and mach tuck demo and a dutch roll demo. I wasn't totaly comfortable flying in the left seat, but after doing all of those, I feel TONS better over there. Then we had an explosive decompression to an emergency descent with the masks on. Finished that up, and did a max rate descent down to 7000 ft for a CFIT/GPWS demo. Basically it was to show us what the system will do when you start getting close to the things that will make you go "splat." Did the recovery manuever from the GPWS warning and leveled out.
Next was some flight control malfunctions. First off was an aileron PCU runway. Not much to do other than catch it and fight the airplane. 'Course I found out the left seat in this particular sim aparently doesn't have full travel on the ailerons. Plane rolled over on it's back even though I was about to break the friggin yoke. The FO's side still had plenty of travel, but the CA side was to the stops. Me thinks someone needs to re-calibrate. Anyway, averted that crisis by running the QRH procedures. Then we got the dreaded stab trim runaway. I felt the yoke start to push back against me....hard, so I hit the disconnect button. I hit it too soon for the teaching part of the lesson, though. It wasn't out of trim very badly, so the instructor spun my trim up so I could feel what it's like to fly it fighting the stab trim (AP doesn't work in this situation).
So, fighting this beast (left arm was totally extended just to keep the nose down and in level flight), I flew the southern DME arc into the ILS 27 into Helena.....and no runway in sight at minimum. So, now I do the go around out of trim. Reset to about a 5 mile final, and then land it out of trim.
Normal takeoff out of Helena for vectors on the northern DME arc for the ILS 27.....no FMS. So, we do the whole thing green needles with the RMI up for the VOR. It's just like doing a DME arc in a Seminole with an RMI, you're just going really fast. Come in on that approach, land and I'm done.
All in all, the lesson went really well. I forgot to de-select 1/2 bank when I got to Vt on the SE procedure, but other than that I managed to shuffle my way through without any other screw ups.
Tomorrow I've got the insanely early 4 am sim slot, and it's winter ops procedures, an ISIS only approach, an RA recovery and a LOC BC approach. After that, it's one more sim, and on to the checkrides.
