<sigh>
Lots of (mis)information available on this topic. I'd seriously recommend reading this page by one of our users. One of the best summations available anywhere:
http://www.midlifeflight.com/faq/faq.php?s=1
quoted from the linked page above:
Rule 1. If you are a recreational, private or commercial pilot, you may log PIC any time you are the sole manipulator of the controls of an aircraft you are rated for. [61.51(e)(1)(i)] "Rated" means the category and class (and type, if a type rating is necessary for the aircraft) that is listed on the back of your pilot certificate. Nothing else matters. Not instrument ratings. Not endorsements for high performance, complex, or tailwheel aircraft. Not medical currency. Not flight reviews. Not night currency. Nothing. There are no known exceptions.
Note that the rule is different for sport pilots who have endorsed "privileges" for aircraft in their logbooks insetad of ratings on their pilot certifciates.
another:
May a Safety Pilot Log PIC Time?
It depends. If the safety pilot is also acting as PIC (in charge of the flight), then the safety pilot may log PIC time while the flying pilot is under the hood. If not, the safety pilot is permitted to log second-in-command time. To understand the answer, make sure that you first understand the "golden key" to logging mentioned in the general logging PIC FAQ - the FAA treats "acting as pilot in command" and "logging pilot in command time" under FAR 61.51 as
completely different concepts. Unless 61.51 specifically directs you to it, answering a logging question by including the word "acting" or pointing to any other FAR is
always a mistake.
Logging PIC time as a safety pilot is one of those times that 61.51 tells you to look somewhere else. As usual, let's start with 61.51. 61.51(e)(1)(iii) tells us that if you are a private or commercial pilot, you may log as PIC any time you are acting as PIC (in charge) of a flight on which more than one pilot is required by the regulations. More than one pilot may be required because the aircraft is not certified for single-pilot operations. But there are other situations as well. One is set up for us by 91.109(b):
By reading these 2 paragraphs I would be led to believe that a private pilot rated individual with an expired medical (and legally blind) and expired flight review could serve as safety pilot (PIC) in a turbine single (thinking PC-12, C-208 etc...).
Your FSDO might buy that but I know the FSDO/examiner that I work with wouldn't accept it. If you read hard enough the regs will tell you anything you want. I think we will have to agree to disagree on this subject!
