So after two days off, we got back in the swing of things by doing what we call "GFS." This used to be called CPT (cockpit procedures training,) but they changed the name when we got the nifty touch screen things.
So, started off doing first flight of the day checks as if we just walked up to the airplane from an overnight. External AC was connected, so I didn't start the APU. Unfortunately, I also forgot to check for the dreaded "APU FIRE FAIL" message. Soon as I went to check the APU fire loops the APU shut itself down. Guess who won't make THAT mistake again. Rest of the flight deck inspection check went off without a hitch. Took a major effort to get back in the swing of doing things to get ready for a flight. It's amazing how you start forgetting the little things like getting a clearance, ATIS and programming the FMS when you haven't done it for almost a month. Oh, yeah. And you're in a different seat. Normally, the FO would do this, but my sim partner was enthralled by me doing the flight deck inspection check, I guess.
Honestly, if the roles had been reveresed, I might have done the same thing and been too busy following along.
Get all the checklists done, get ready to push back, get the clearance to start the engines. Shocker. No light off. So we go through the procedures on that one. MX says "Try it again, just use the other ignition." Well, I see the ITT shooting through the roof, call it a "hot start" and follow those procedures. The instructor pointed out that the ITT never hit 900 and I never got a "hot" icon, but I did the right thing. I saw the trend and stopped it. His advice, though, was in the training world to wait until you see a "hot" icon. Otherwise, the QRH has no guidance. I thought that was kinda odd, but whatever.
After finally getting the engines started, we did the taxi checks, before takeoff checks, and got cleared onto the runway. No surprise, but we got an engine fire before V1. So, we aborted, went through the QRH procedures, then talked about when we evacuate and we we wouldn't evacuate on the runway. In case of a fire, you don't really know if it's gonna flame up again, so it's not a bad idea to evac. On the other hand, people generally get hurt during evacs. So, if the fire's under control, you could taxi to a remote area and get the people off through an expiditious deplaning method. Ruling: it's up to the CA and the situations.
We get in the air and do some intercepting and tracking of radials using the FMS. Sounds basic to you 172 guys, but it's odd how you set it up in the FMS to make it track inbound/outbound. If you want to track inbound, you tell the FMS to go direct to the fix, but change the course to the reciprocal of the radial. For example, you're told to track inbound to MEM on the 180 radial. You'd tell the FMS to go to MEM on a 360 course. If you were told to track outbound on the 180 radial, you have to build a fix for it to go to. You have to enter something like MEM180/99 as a fix for it to navigate to. Clear as mud? Yeah. Flying's the easy part.
After that, FA calls and says we've got a guy having a heart attack in the back. I say "Okay, we're declaring an emergency and diverting to Jackson, MS." Instructor leans up and says "Crap. I didn't know you were that far south. Just go to MEM. For the record, Jackson is a better call, but, uh, I want you to go to MEM." So, I'm juggling the FA, ATC, my FO and dispatch, and get everything set up for the approach into MEM......an approach I never got to fly.
The rest of the time was spent going over profiles like stalls (both in the takeoff and landing config), steep turns, SE and two engine non-precision approaches, SE and two engine precision approaches, engine failures after V1, ILS PRM approaches, and SE and two engine go-arounds. Basically, he wanted to see if we knew the profiles or not.
So, tomorrow, it's back in the GFS for more training there. Friday, I've got a stage check in the GFS. After that, it's in the sim on Monday.
