Is this a joke? When does one ever do that and why?
From what the FAA guy I was talking to said, at this level, if you've got an ATP and bust the ride, they might just take you down to the CMEL level. Might yank your type. Since it was an FO, if they busted the ride, I'm guessing the SIC type got yanked, which would probably nix employment status. If it was a REALLY bad ride, they might be down the PPL level. Like I said, I don't know the details on the person's ride, so that's all I can say.
On to day four....
Went over the insane performance problem from last night. The discussion was prefaced with "You won't get something this screwed up on your oral, and if it happens on the line, just call dispatch and start over." To start with, they gave us fuel for a 45 minute flight to an alternate that was over an hour away. It was a 3585 flight, but they only gave us ONE alternate when we needed two. We didn't have a takeoff alternate, and we needed that as well. Oh, and they added the fuel wrong on top of all of that. The way I wound up working it was bumping about 9 passengers (policy is we bump passengers and not bags....it's cheaper) for extra fuel, picking MOB as not only my take-off alternate (we were leaving PNS) but as my hard alternate for 3585 and adding LIT as my soft alternate. Of the 9 guys in class, we had 9 different ways this flight was changed. All of them were valid.
After that brain melting episode, we talked a bit about the MKE accident a few years back. We had a flight enroute to MKE when they got a HYD 1 LO PRESS message. Turns out something happened and they lost ALL the fluid in the #1 system. QRH says "land at nearest suitable airport." They contacted MX control to discuss things. This is where the first mistake came in. Dispatch never heard a word, so they were dropped out of the loop. MX said "What's the temp on your hydraulic pump." Crew's response "It's at zero." MX says "As long as it stays there, you're good to go to your destination."
Now, the CRJ guys that know the hydraulics are probably saying the same thing I did. Where the hell can you find the temp for the hydraulic PUMP? Answer: you CAN'T. The hydraulic synoptic page displays the temp of the FLUID. It probably said 0 b/c there wasn't any fluid to measure. Mistake number two. Mistake number three was not following the QRH when it said "land at nearest suitable airport." If MX tells me to do something contrary to the QRH, we can talk about it on the ground, not in the air. I'm gonnd do what the book says. Oh, mistake number 4.....all these conversation tooks place over ACARS....which was "deferred." Mistake number 5, going back to nearest suitable airport.....they flew over not only BUF but DTW as well. When they finally got to MKE, it was a contaminated runway, and the plane went off the edge, across some grass and finally ended up on the ramp......a few hundred yards from the gate. The final nail in the coffin was that they taxiied to the gate rather than being towed in after departing the runway and off-roading the airplane.
We're not going over these things to ridicule the pilots or the decisions they made. We're doing it to learn from their mistakes. TVC is a HUGE thing for me. The CA on that flight had the deck stacked against him from the start, so now I've got all of that in the back of my mind so I hopefully won't make those same mistakes. Hopefully, I can recognize that chain of events before it gets too far gone.
This led nicely into the performance discussion on contaminated runways. Went over performance weight reductions, V1 reductions, actual landing distance vs required runway length, and types of contaminates (snow, slush, ice, etc). Talked a little about how, why and what brought about our contaminated landing charts, and it about made my head explode. It also made me realize that I'm giving myself a buffer on that chart bigger than I had originally intended. For example, the charts are assuming max reverse thrust at the point of touchdown. It takes several SECONDS for the reversers to kick in. Meanwhile, you're merrily bolting down the runway at 130+ kts. Finished that part up with de-icing, hold over charts, and flex thrust (when, where and why we use it).
After lunch, a rep from dispatch came in to talk to us, and I learned a lot of things. For example, when we divert and use the "Divert" option in ACARS to notify them.....it actually cuts them off from communications until the new route is built and the flight is re-released. Meanwhile, the flight crew is screaming "Why isn't dispatch talking to me!" at the box. Answer: b/c they can't. I never knew that. They're suggesting notifying them of a divert using a free text message instead so the line of communications stays open. Rest of the afternoon was pretty much on our own wandering SOC talking to dispatchers, maintenance control and crew scheduling. One of my wife's friends is a scheduler who happened to be starting work right then, so I had her show my their side of the operation. CrewTrac looks a LOT different from that end than on my end.
Talked to several dispatchers, so I was able to put faces with names I see on the releases, and I learned what they can and can't do. Answer is they have access to a lot more stuff than I knew they did. So, that opens them up even more as a resource.
After class, got together with my sim partner again and we did flows until we could go through them without missing a beat. I'm pretty confident I'd pass my checkride tomorrow if it were just on the Flight Deck Inspection checklist.
He has trouble with the electrical system, so I spent about an hour just grilling him with questions on the electrical system. Helped me out, too, since I was having to dig deep to come up with questions. He also came up with some I didn't know. Tomorrow's my turn to get grilled on my weak spot: the fuel system.
