Stick vs. Yoke
troopernflight
Has anyone found it difficult to start out training on the stick (i.e. Diamond aircraft), and converting to yoke later in their training? The way I see trends going in these newer commercial aircraft we may eventually all convert back to stick..... any comments?
I started off in a Citabria and didn't have any major problems when transitioning to aircraft with a yoke. Only thing that bugged me initially was getting used to primarily flying with my left hand rathern than my right. After a while, it all becomes second nature.
I am still working on my PPL, but started back home in Pittsburgh in a Diamond DA20 Eclipse. When I moved to Ann Arbor for school, I had to switch into a Piper PA28, with the yoke. I've found the transition to be incredibly easy. Once you get into it for a while, flying is flying and an airplane is an airplane (at the smaller levels - not too sure about that once you get into heavy metal!). You'll be fine with any transition and find it much easier than you anticipated.
It's not an issue at all. I switched between a SuperCub, Diamond, and Cessna all through my training. No problems at all.
Only "stick" time I have is in a Pitts S2b, and it took a while to get used too...Than again, the airplane is a pure aerobat, and i'm sure it would be different than a diamond or citabria.
I personally think it is easier to go from flying a stick to flying a yoke, but then again, that is just me...
Thoughts from others on this?
They all fly the same. It really is no big deal at all to switch. I find the stick more intuitive, but that is personal preference. I like the yoke better when flying IFR, because I like to put the charts on a yoke clip. I don't like looking down to my leg for the chart.
I'll add to the chorus of "it's not a big deal" either way.
The only change is a loss of "muscle memory" with respect to throttle and control positions, but you will get that when changing between aircraft any time (the throttle difference between a Skyhawk and a Cherokee, for example).
I think the same goes for when it's time to get that CFI (or be a right-seater in a heavy) and fly from the right side. A little different for a flight or so, then no big deal.
My preference is the left hand throttle, right hand stick config, but that's probably because that's how I have most of my flight time. I'm sure if I had most of my time in a yoke-left, throttle-right position then that is what I would prefer.
I honestly thought that I would have an issue transitioning from a yoke to a stick but that was not the case at all. It may take a little getting used to and by that I mean a few minutes!:)
Did my Private training in a Cessna 172. Then moved onto a Diamond DA40 for my instrument training. I thought I'd have a bit of "getting used to" as far as yoke-to-stick transition, but that wasn't the case at all. No problem whatsoever. Felt completely natural right after the first rotation.
I switch back an forth from Diamonds to real airplanes several times a day. I VASTLY prefer the yoke, but more from a "Knees and Nuts" perspective.
I prefer the left hand throttle,right hand stick.Have flown a Luscombe quite a bit but really didnt like that arrangement.Never have flown a Diamond. T.C.
Yeah, but how many thousands of hours do you have with this configuration?:D
I knew it was only a matter of time before one of those jokes came out. It's funny to watch the metamorphosis of these forums! :)
