Are You Applying FDC Notams?
"Cool status"? Hell, I'm still trying to figure out who's in the much ballyhooed "inner circle"!
I'm bloody watching "Ramsays Kitchen Nightmares" on BBC-America on the telly, I'm wracking me brains out because I'm picking up annoying "Britisms".
Spend too much time flying around England and you start ending your transmission with "Cheeriooo" :tease:
Back on topic. Here. Hope this helps out some folks:
[FONT=Verdana, Arial,Helvetica]What are NOTAMS?
[/FONT]
[FONT=Verdana, Arial, Helvetica][SIZE=-1]NOTAM, "NOtice To AirMen", are notices containing essential flight operation information not known sufficiently in advance to publicize by other means. Just like weather reports, they include endless abbrieviated text (known as a contraction) which are sometimes difficult to figure out. Translate NOTAMs here![/SIZE][/FONT] [FONT=Verdana, Arial, Helvetica][SIZE=-1]Types of NOTAM's include the following: [/SIZE][/FONT]
    [FONT=Verdana, Arial, Helvetica][SIZE=-1]NOTAM(D): Information that requires wide dissemination and pertains to
    enroute navigational aids, civil public use landing areas listed in the Airports Facility
    Directory and aeronautical data related to IFR operations. [/SIZE]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica][SIZE=-1]NOTAM(L): Information that requires local dissemination, but does
    not qualify as NOTAM(D) information. This includes, but is not limited to, aircraft
    jettisoning fuel, bird activity, moored balloons, military training activity, etc. [/SIZE]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica][SIZE=-1]FDC: Information that is regulatory in nature pertaining to flight including,
    but not limited to, changes to charts, procedures, and airspace usage. [/SIZE]
    [/FONT]It includes TFRs.
[FONT=Verdana, Arial,Helvetica]NOTAMs Translated!
[/FONT]
Other contractions used by the National Weather Service and FAA are available at: Weather Contractions or [FONT=Arial,Helvetica]Abbreviations list. [/FONT][FONT=Arial,Helvetica] If you don't find what you're looking for, contact me and i will research it for you. [/FONT]
A
ABN Airport Beacon
ABV Above
ACC Area Control Center (ARTCC)
ACCUM Accumulate
ACFT Aircraft
ACR Air Carrier
ACT Active
ADJ Adjacent
ADZD Advised
AFD Airport Facility Directory
AGL Above Ground Level
ALS Approach Light System
ALT Altitude
ALTM Altimeter
ALTN Alternate
ALTNLY Alternately
ALSTG Altimeter Setting
AMDT Amendment
AMGR Airport Manager
AMOS Automatic Meteorological Observing System
AP Airport
APCH Approach
AP LGT Airport Lights
APP Approach Control
ARFF Aircraft Rescue & Fire Fighting
ARR Arrive, Arrival
ASOS Automated Surface Observing System
ASPH Asphalt
ATC Air Traffic Control
ATCSCC Air Traffic Control System Command Center
ATIS Automatic Terminal Information Service
AUTH Authority
AUTOB Automatic Weather Reporting System
AVBL Available
AWOS Automatic Weather Observing/Reporting System
AWY Airway
AZM Azimuth
B
BA FAIR Braking action fair
BA NIL Braking action nil
BA POOR Braking action poor
BC Back Course
BCN Beacon
BERM Snowbank/s Containing Earth/Gravel
BLW Below
BND Bound
BRG Bearing
BYD Beyond
C
CAAS Class A Airspace
CAT Category
CBAS Class B Airspace
CBSA Class B Surface Area
CCAS Class C Airspace
CCLKWS Counterclockwise
CCSA Class C Surface Area
CD Clearance Delivery
CDAS Class D Airspace
CDSA Class D Surface Area
CEAS Class E Airspace
CESA Class E Surface Area
CFR Code of Federal Regulations
CGAS Class G Airspace
CHG Change
CIG Ceiling
CK Check
CL Center line
CLKWS Clockwise
CLR Clearance, Clear(s), Cleared To
CLSD Closed
CMB Climb
CMSND Commissioned
CNL Cancel
COM Communications
CONC Concrete
CPD Coupled
CRS Course
CTC Contact
CTL Control
D
DALGT Daylight
DCMSND Decommissioned
DCT Direct
DEGS Degrees
DEP Depart/Departure
DEPPROC Departure Procedures
DH Decision Height
DISABLD Disabled
DIST Distance
DLA Delay or Delayed
DLT Delete
DLY Daily
DME Distance Measuring Equipment
DMSTN Demonstration
DP Dew Point Temperature
DRFT Snowbank/s Caused By Wind Action
DSPLCD Displaced
E
E East
EB Eastbound
EFAS En Route Flight Advisory Service
ELEV Elevation
ENG Engine
ENRT En route
ENTR Entire
EXC Except
F
FAC Facility or Facilities
FAF Final Approach fix
FAN MKR Fan Marker
FDC Flight Data Center
FI/T Flight Inspection Temporary
FI/P Flight Inspection Permanent
FM From
FREQ Frequency
FNA Final Approach
FPM Feet Per Minute
FREQ Frequency
FRH Fly Runway Heading
FRI Friday
FRZN Frozen
FSS Automated/Flight Service Station
FT Foot, feet
G
GC Ground Control
GCA Ground Control Approach
GOVT Government
GP Glide Path
GPS Global Positioning System
GRVL Gravel
H
HAA Height Above Airport
HAT Height Above Touchdown
HDG Heading
HEL Helicopter
HELI Heliport
HIRL High Intensity Runway Lights
HIWAS Hazardous Inflight Weather Advisory Service
HLDG Holding
HOL Holiday
HP Holding Pattern
HR Hour
I
IAF Initial approach fix
IAP Instrument Approach Procedure
INBD Inbound
ID Identification
IDENT Identify/Identifier/Identification
IF Intermediate fix
ILS Instrument Landing System
IM Inner Marker
IMC Instrument Meteorological Conditions
IN Inch/Inches
INDEFLY Indefinitely
INFO Information
INOP Inoperative
INSTR Instrument
INT Intersection
INTL International
INTST Intensity
IR Ice On Runway/s
K
KT Knots
L
L Left
LAA Local Airport Advisory
LAT Latitude
LAWRS Limited Aviation Weather Reporting Station
LB Pound/Pounds
LC Local Control
LOC Local/Locally/Location
LCTD Located
LDA Localizer Type Directional Aid
LGT Light or Lighting
LGTD Lighted
LIRL Low Intensity Runway Lights
LLWAS Low Level Wind Shear Alert System
LM Compass Locator at ILS Middle Marker
LDG Landing
LLZ Localizer
LO Compass Locator at ILS Outer Marker
LONG Longitude
LRN Loran
LSR Loose Snow on Runway/s
LT Left Turn
M
MAG Magnetic
MAINT Maintain, maintenance
MALS Medium Intensity Approach Light System
MALSF Medium Intensity Approach Light System with Sequenced Flashers
MALSR Medium Intensity Approach Light System with Runway Alignment Indicator Lights
MAPT Missed Approach Point
MCA Minimum Crossing Altitude
MDA Minimum Descent Altitude
MEA Minimum En Route Altitude
MED Medium
MIN Minute
MIRL Medium Intensity Runway Lights
MLS Microwave Landing System
MM Middle Marker
MNM Minimum
MNT Monitor/Monitoring/Monitored
MOC Minimum Obstruction Clearance
MON Monday
MRA Minimum reception altitude
MSA Minimum Safe Altitude/Minimum Sector Altitude
MSAW Minimum Safe Altitude Warning
MSG Message
MSL Mean Sea Level
MU MU Meters
MUD Mud
MUNI Municipal
N
N North
NA Not Authorized
NAV Navigation
NB Northbound
NDB Nondirectional Radio Beacon
NE Northeast
NGT Night
NM Nautical Mile(s)
NMR Nautical Mile Radius
NONSTD Nonstandard
NOPT No Procedure Turn Required
NR Number
NTAP Notice To Airmen Publication
NW Northwest
O
OBSC Obscured
OBST Obstruction
OM Outer Marker
OPR Operate
OPS Operation
ORIG Original
OTS Out of Service
OVR Over
P
PAEW Personnel and Equipment Working
PAPI Precision Approach Path Indicator
PAR Precision Approach Radar
PARL Parallel
PAT Pattern
PAX Passenger
PCL Pilot Controlled Lighting
PERM Permanent/Permanently
PJE Parachute Jumping Exercise
PLA Practice Low Approach
PLW Plow/Plowed
PN Prior Notice Required
PPR Prior Permission Required
PREV Previous
PRN Psuedo random noise
PROC Procedure
PROP Propeller
PSR Packed Snow on Runway/s
PTCHY Patchy
PTN Procedure Turn
PVT Private
R
RAIL Runway Alignment Indicator Lights
RAMOS Remote Automatic Meteorological Observing System
RCAG Remote Communication Air/Ground Facility
RCL Runway Centerline
RCLL Runway Centerline Light System
RCO Remote Communication Outlet
REC Receive/Receiver
RELCTD Relocated
REIL Runway End Identifier Lights
REP Report
RLLS Runway Lead-in Lights System
RMNDR Remainder
RNAV Area Navigation
RPLC Replace
RQRD Required
RRL Runway Remaining Lights
RSR En route Surveillance Radar
RSVN Reservation
RT Right Turn
RTE Route
RTR Remote Transmitter/Receiver
RTS Return to Service
RUF Rough
RVR Runway Visual Range
RVRM Runway Visual Range Midpoint
RVRR Runway Visual Range Rollout
RVRT Runway Visual Range Touchdown
RWY Runway
S
S South
SA Sand, sanded
SAT Saturday
SAWR Supplementary Aviation Weather Reporting Station
SB Southbound
SDF Simplified Directional Facility
SE Southeast
SFL Sequence Flashing Lights
SID Standard Instrument Departure
SIMUL Simultaneous
SIR Packed or Compacted Snow and Ice on Runway/s
SKED Scheduled
SLR Slush on Runway/s
SN Snow
SNBNK Snowbank/s Caused by Plowing
SNGL Single
SPD Speed
SSALF Simplified Short Approach Lighting System with Sequenced Flashers
SSALR Simplified Short Approach Lighting System with Runway Alignment Indicator Lights
SSALS Simplified Short Approach Lighting System
SSR Secondary Surveillance Radar
STA Straight-in Approach
STAR Standard Terminal Arrival
SUN Sunday
SVC Service
SW Southwest
SWEPT Swept or Broom/Broomed
T
T Temperature
TAA Terminal Arrival Area
TACAN Tactical Air Navigational Aid
TAR Terminal Area Surveillance Radar
TDZ Touchdown Zone
TDZ LG Touchdown Zone Lights
TEMPO Temporary
TFC Traffic
TFR Temporary Flight Restriction
TGL Touch and Go Landings
THN Thin
THR Threshold
THRU Through
THU Thursday
TIL Until
TKOF Takeoff
TM Traffic Management
TMPA Traffic Management Program Alert
TRML Terminal
TRNG Training
TRSN Transition
TSNT Transient
TUE Tuesday
TWR Tower
TWY Taxiway
U
UFN Until Further Notice
UNAVBL Unavailable
UNLGTD Unlighted
UNMKD Unmarked
UNMNT Unmonitored
UNREL Unreliable
UNUSBL Unusable
V
VASI Visual Approach Slope Indicator
VDP Visual Descent Point
VGSI Visual Glide Slope Indicator
VIA By Way Of
VICE Instead/Versus
VIS Visibility
VMC Visual Meteorological Conditions
VOL Volume
VOR VHF Omni-Directional Radio Range
VORTAC VOR and TACAN (colocated)
W
W West
WB Westbound
WED Wednesday
WEF With Effect From or Effective From
WI Within
WIE With Immediate Effect or Effective Immediately
WKDAYS Monday through Friday
WKEND Saturday and Sunday
WND Wind
WPT Waypoint
WSR Wet Snow on Runway/s
WTR Water on Runway/s
WX Weather
Source: USAJOBS
Astronaut Candidate
SALARY RANGE: 59,493.00 - 130,257.00 USD per year
To be considered, a bachelor's degree in engineering, science or math and three years of relevant professional experience are required. Typically, successful applicants have significant qualifications in engineering or science, or extensive experience flying high-performance jet aircraft.
ASTRONAUT CANDIDATE (PILOTING BACKGROUND):
1. Bachelor’s degree from an accredited institution in engineering, biological science, physical science or mathematics. An advanced degree is desirable. Quality of academic preparation is important.
2. At least 1,000 hours pilot-in-command time in jet aircraft. Flight test experience is highly desirable.
3. Ability to pass the NASA long-duration space flight physical which includes the following specific requirements:
My observation? They pay strict attention to all NOTAMS. :D
