meritflyer
Is it true that all the guys hired for the Q400 were moved into the Saab or B1900?
What's the status on those birds with the whole SAS issue?
If it was a SAS mx issue, how does Bombardier explain the multiple accidents that occured prior and with other carriers?
Concerns over the Q400 have already appeared in Japan’s media, with several newspapers reporting on an ANA/JAC survey into the Q400. The survey, covering the period 28 June 2003 to 20 May 2006, found there were 52 cases where Q400s had made emergency landings or had to return to departure airports. Of these cases, 49 stemmed from problems with the aircraft, and included difficulties with: the flight control system; landing gear; engine oil pumps; and hydraulic pressure systems.
It's all finger pointing. No operator wants to have their maintenace operations scrutinized and it's easy to place the blame on the manufacturer, just like it's easy to say it was pilot error whent there's a mishap. All aircraft are under warrenty for 5-10 years. Anything factory installed that malfuntions of breaks is covered and reimbursed by the manufacturer including parts and labor provided by the customer. Bombardier's downside is that they're like Airbus. Everything is divided up between other companies. Goodrich and Messier Dowty, manufactures the landing gear, Shorts manufactures the wings, control surfaces and thrust reverser componants, as well as the tail section and horizontal stabilator.
There was a memo put out about a month or so ago. To paraphrase, it stated that 'current crewmembers completing Q400 training will be returned to the line in the current equipment until the aircraft arrives on property..."
Also, it stated that rather than paying you for your highest qualified rate, Q400 scales would not be paid out until sometime in the neighborhood of route trial completion.
That being said, I wouldn't put it past Pinnacle/Colgan to say the Q400 program was on time, but know it's delayed and fills gaps in the other fleet rosters until then.
I heard that the production line at Bombardier was behind schedule.. anyone know more about that?
I hope this is pure conversation and not more sour grapes from XJET guys?
Yeah, ask RegionsAir how those Saab 340s are working out.New airframe types are ALWAYS interesting for any airline.
That part is true- if you're a Saab CA they will train you on the Q then send you back to the Saab until you're needed.
However- I wouldn't think they would train a new HIRE two airframes with the intention of keeping only on one.
Absolutely not. The Q400 will go into service on time, on budget according to PNCL. Colgan and the parent company have made it clear that the SAS incidents are isolated and they think it's an SAS maintenance issue.
