What he said.Why push an airplane OUTSIDE its boundaries?![]()
What he said.
I'm no Internet Federale, but there is a big difference between busting a cloud clearance and exceeding an aircraft limitation. The people who fly that aircraft after you trust that you haven't been playing test pilot in it.
I'll trust then that every time you hit a bump above max maneuvering in the future you'll ground that plane. Therefor, the next person who uses it isn't in danger. And you'll see that it gets a full structural test.![]()
As you're not any kin of mine, I'm truly not concerned what you do. Hopefully your act or any subsequent acts will not compromise or harm anyone else but yourself. (Hey, there are plenty of candidates eligible for the Darwin Award) You got your thrill. . .fine. I'm happy it turned out not to be catastrophic for you, but a learning experience and reminder for those not to push the envelope. I'm simply hoping because the cavalier attitude you have about doing something both dumb and potentially compromising, yet getting away with it that no one else mimics your stunt resulting in negative consequences.
mode now on!
Full structural test? Why don't you try flying it to 19000! Dare you! Just let me know when, for you'll need an audience next time. Who knows - the photo of the altitude could have been photoshopped!Go ahead. . .do it again. I DARE you!!!
mode off!
I'm certain there are air traffic controllers who are also pilots on this forum who've read this thread. They'll read about your antics and truly keep the thought in the back of their minds. There will, unfortunately, probably be someone else, perform a stupid pilot trick similar to what you did and got away doing. If that person survives, I'm believing his "N" number will receive the appropriate FAA attention it truly deserves hopefully serving as a deterent for others not to be so careless.
Which aircraft limitation was exceeded?
I never actually said he exceeded a limitation. I was just curious if he would reply that he hadn't exceeded one, or if he thought he had but would come up with some ridiculous hyperbole to rationalize it.Which aircraft limitation was exceeded?
... would come up with some ridiculous hyperbole to rationalize it.
Isn't there a service ceiling on this aircraft?
Yes, but it's not an operating limitation. I would interpret a service ceiling as a performance measurement. If the aircraft had a "Maximum Operating Altitude", different story. ("Service ceiling" doesn't appear in Part 23.)
Wow, I busted the 1 5 2 cloud cover VFR rules! I should take a picture of that puff of cloud that I missed by 20 feet and post it.Phew! Got that off my chest.
Now. . . .OFF!
Isn't there a maximum operating altitude on this aircraft?
No. Scanning through the TCDS, the piston-engined aircraft that I see them on are mostly turbo-charged or pressurized and the altitudes tend to be 20 or 25,000, although the DA40 has one of 16,404.
One day you decide to run for the Senate someone's gonna slip the picture of that cloud under your door and...![]()
The service ceiling it is defined as the highest altitude at which an aircraft can maintain a rate of climb of 100 feet per minute.
TCDS IM.A.051 Cessna Aircraft Model 172
:yup:
So much for my political aspirations! The real deal breaker would be someone named "Hans" showing up with a picture of me and his mom hanging out in a bar while I was stationed in Germany:nana2::banghead:.
