Risk management isn't something that complex like you are trying to make it.
No, it's not complex, but it certainly isn't a clear cut formula, either. You say I'm making it too complex, I say you're making it too simple.
For what it's worth, I'm not just pulling this stuff out of my butt, either. John and Martha King talk about pretty much what I've been talking about.
If one has risky behavior in aviation it WILL get you one day. Hopefully you won't get hurt or hurt anyone else, but those that don't minimize the risk when they fly, will get caught one day.
I completely agree.
Blowing a tire, having to replace the brakes, and having gear issues WILL happen. Excessive heat and cold expansion to an engine in a rental 172 because someone wants to try to fly in the flight levels isn't normal rental issues that come up.
You're right, it's not normal, but it still falls in to the "stupid renter pilot" category. I wouldn't get upset with sdvc...whatever his name is...for abusing the engine, I'd explain to him what's going on and train him how to manage the engine in a better way. It's a mistake made out of ignorance, not recklessness. Just like how some pilots are hard on the gear or brakes, this instance was hard on the engine.
When you operate the engine outside of what it was designed to do, you are not minimizing the risk. I doubt they designed the engine to be leaned out at 17,999 feet. See, not that hard to minimize the risks associated with flying.
I don't know enough about the engine manufacturing specs to comment one way or the other on high altitude performance. I know that the Piper Twin Commanche and Piper Seminole engines are certified to somewhere in the neighborhood of FL180-FL200 though, and I don't think those engines are significantly different than a 172's. They're all small, normally aspirated Lycomings.
I know I can land the 1900 fully loaded in about 1000 feet if I wanted to. I actually HAD to, one time because some yahoo wasn't talking on the radio and had to hold short of the runway to prevent an accident. Anyway, the company dictates we must use 4000 feet of runway to land the airplane. It is a set limitation that I follow. There have been times I have been offered 33R in BOS to land on. If we accepted it we would get right in, no flow delays. It is not within our margin of safely, so we don't use it. I know I can land an airplane there safely but why chance it? I know how the 1900 preforms on short runways, why do I need to land on it to prove a point?
Passenger carrying Part 121 ops are a completely different animal than Part 61/91 flight training ops.
There are all kinds of limitations set in the 121 world that are highly conservative. Nothing wrong with that...in fact, as a passenger, I'm quite thankful for it.
But it's not a fair anology to compare "risk management" at an airline to "risk management" as a private pilot. There are totally different risks and rewards involved, and the threshold for acceptable risks and rewards is different.
You want to see how a 172 reacts high, slow, and heavy? Take it to 13,000 feet. Is that 5000 feet REALLY going to make a difference that one can tell, that being between 13,000 and 18,000 feet?
Are you serious? When was the last time you flew a light plane up high?
It absolutely makes a difference. Saying there is no noticeable difference between 13k and 18k is like saying there's no difference between flying solo versus flying loaded to max gross weight, flying on a 60 degree day versus a 100 degree day, or landing on a calm day versus landing with a 10 knot crosswind.
It's not that there is a shockingly huge difference, but it is certainly a noticeable difference and is worth exploring. I consider it especially important to explore this region because it's on the limits of the plane's capabilities. It's usually when a pilot is pushed to the limits by external factors that they get in to accidents--times when it would be especially nice to have experience flying to the limits so they could know better what to expect.
Even though you don't fly your Beech 1900 into runways less than 4000 feet long, isn't it a good feeling knowing you *could* put it down in 1000 feet if you had to, because you've actually done it in the past? The same could be said for altitude. Nobody intends to be in a spot where they *have* to fly at their service ceiling, but you and I both know there are times in flying where crap happens. When that crap happens, knowing the absolute, precise limits of the plane could make a big difference. Going to 13k when you could go to 18k doesn't represent truly finding the limits of anything.
The reason I feel so strongly about this is because it almost caught me once. I won't go in to all the details, but basically there was a time when I was flying my 140 and I *needed* every ounce of performance out of it. I'm talking, "perfectly coordinated turns, mixture perfectly leaned, pitched perfectly for Vx/Vy (because they had converged!)" kind of performance, and I needed it at 400 AGL. It was a nice feeling knowing I'd already been there and done that in the practice area in the past, so I knew exactly how the plane handled, rather than try to figure it out as I zoomed along at my service ceiling, which happened to be at 400 AGL during that experience.
