You are the PIC for a Part 135 freight company flying a multi-engine twin. You take off under day VFR conditions. Very shortly after takeoff, you realize you lost a vacuum pump. The other one is working just fine. You have work on board. What would you do?
Well I don't know 135 regs, but my question would be:
Is it VFR along the entire route and destination?
I am guessing that there is some hard 135 regs as to what is required.
Yes
Nope. Not when the discovery was made in flight.
To hell with it, just get there. It's not gonna get fixed in flight and I'm not diverting for a vacuum pump when I have another. If BA can fly from LA to London with an engine not working, I can make a couple hundred miles with one vacuum pumpWell, if it is VFR along the entire route, and at the destination, and you have another vacuum pump working, I would think it would be o.k.
Is there an electric backup for the instruments?
Are there company regs? I would think the company would ask why did one not continue on if it were VFR?
I think it would be ok to continue in VFR conditions. However, I would write up the vacuum pump once I got to a maintenence base.
What if your destination wasn't a maintenance base? Are you saying that you would depart with a know mechanical discrepancy? I know that you commuter guys always say that you never write anything up at an outstation because you have no maintenance there. Why is that? Is it because you are all such company guys that you will violate FARs to help the company? Are you too lazy to write it up at an outstation? Worried that you might lose pay somehow if you cancel at an outstation and a reserve has to take your next trip at the hub? If it's broke, write it up wherever you are. Call me when you get it fixed, I'll be in the crew lounge. Oh, you don't have those at most outstations do you?
Yes...if it can legally be MEL'd and you can stay within the FARs...
Look at the original question...he asked if he lost a vacuum pump in day VFR...Since pilot4500 and I are the only ones that have mentioned a Minimum Equipment List obviously we know what we are doing and like I posted earlier, my airplane can be DISPATCHED with one vacuum pump inoperative and the flight occurs with the LIMITATION that it is day VFC only...guess that means it is perfectly legal for me to depart with a dead vacuum pump
Same goes for stuff like a gyroscopic rate of turn/slip skid inicator, a VOR reciever, clock, landing light, VHF reciever, and ammeter/voltmeter...I can legally dispatch into day VMC with any of these out of service. Now that being said, is it necessarily smart...depends on the situation.
Biggest thing is to check your MEL stay within the regs and keep safety in mind above anything else, no matter what your reputation at your company may become.
"Well, I don't want everyone at work to think I'm a pu$$y."Now how would you answer this question if asked on a part 135 oral?
Pretty much what I thought.
If you will read his original question closer, he had already departed, then the pump failed. He wanted to know what to do. He would be perfectly legal and safe to continue. MEL has nothing to do with his scenario, as MELs only pertain to dispatch and are not used inflight.
If he did an air-turnback in day MVC because of a vacuum pump failure, he would be instantly labeled a pu$$y by everyone at Airnet, his fellow pilots, dispatch, mx and the flight department.
