Cessnaflyer
Wooooooooooooooooooooooooooooooo
Here is a quick list of what was covered in my oral and checkride. Each bullet is a separate task within the area of operation.
I. Fundamentals of Instruction:
I would suggest that you go into that oral like you own it and you show confidence in what you are teaching. It will help how you feel right away.
- THE LEARNING PROCESS
- HUMAN BEHAVIOR AND EFFECTIVE COMMUNICATION
- THE TEACHING PROCESS
- TEACHING METHODS
- CRITIQUE AND EVALUATION
- FLIGHT INSTRUCTOR CHARACTERISTICS AND RESPONSIBILITIES
- PLANNING INSTRUCTIONAL ACTIVITY
- PRINCIPLES OF FLIGHT
- AIRPLANE FLIGHT CONTROLS
- AIRPLANE WEIGHT AND BALANCE
- NAVIGATION AND FLIGHT PLANNING
- FEDERAL AVIATION REGULATIONS AND PUBLICATIONS
- NATIONAL AIRSPACE SYSTEM
- LOGBOOK ENTRIES AND CERTIFICATE ENDORSEMENTS
- CERTIFICATES AND DOCUMENTS
- OPERATION OF SYSTEMS
- PERFORMANCE AND LIMITATIONS
- Pylon Eight's
- PREFLIGHT INSPECTION
- SINGLE-PILOT RESOURCE MANAGEMENT
- TAXIING—LANDPLANE
- BEFORE TAKEOFF CHECK
- RADIO COMMUNICATIONS AND ATC LIGHT SIGNALS
- TRAFFIC PATTERNS
- AIRPORT/SEAPLANE BASE, RUNWAY AND TAXIWAY SIGNS, MARKINGS, AND LIGHTING
- SHORT-FIELD TAKEOFF AND MAXIMUM PERFORMANCE CLIMB
- SOFT-FIELD TAKEOFF AND CLIMB
- SLIP TO A LANDING
- GO-AROUND/REJECTED LANDING
- SHORT-FIELD APPROACH AND LANDING
- STRAIGHT-AND-LEVEL FLIGHT
- STRAIGHT CLIMBS AND CLIMBING TURNS
- STEEP TURNS
- CHANDELLES
- S-TURNS ACROSS A ROAD
- EIGHTS ON PYLONS
- POWER-OFF STALLS (PROFICIENCY)
- ELEVATOR TRIM STALLS (DEMONSTRATION)
- SPINS (accepted endorsement in lieu of)
- CONSTANT AIRSPEED CLIMBS
- TURNS TO HEADINGS
- EMERGENCY APPROACH AND LANDING (SIMULATED)
- SYSTEMS AND EQUIPMENT MALFUNCTIONS
- EMERGENCY DESCENT
- POSTFLIGHT PROCEDURES
- RAMPING
