I'm here...mostly lurking nowadays though.:bandit:
B757-Undeniably the best aircraft I've ever flown! Boeing took all the good traits of past aircraft and none of the bad and made the B757. Performance out the wazoo (nothing like a max thrust t/o with an empty airplane), reliable to a fault, nice mix of old (analog) and new(glass) technology and easy to hand fly around the pattern. Climb to altitude was a sprint, especially the ones with the RR engines. Cruising at FL410 back "in the day" when everyone else, except for some corporate guys, was in the low to mid 30's was nice.
B767-300: All the performance of the B757 with the ride of a Cadillac. The B757 was like a Porsche 911 and the B767 was a 5 or 7 series BMW. B767 was a little harder to "grease" on the landing than the B75 but it truly was a sweet ride by anyone's standards.
A300-600: Well, like my mother always said, "If you can't say anything nice.."
Seriously, it is what it is. It's a capable aircraft that does what it was designed to do without all the flare and pizazz of the Boeings. It's older technology that needs to be monitored a little closer, prodded a little more often and treated a little more gently. It's slower, flies lower and tends to be a little less tolerant of mis-management while hand flying or using the automation. It can be a handful in gusty x-winds as it's fat, er..I mean robust wing, tends to ride turbulence like that of a twin otter or single engine Cessna than of a swept wing heavy jet. Not always fun when trying to set 300,000+ lbs down gently between the lines on a dark stormy night.
I was looking forward to bidding the 744 and getting back to the Boeings but decided against moving to PANC to fly it.
The B757's aren't going anywhere soon. The freight companies love'em and one of the few airplanes where you'd be hard pressed to find any pilot who's flown it who doesn't like it!!!!
Back to the lurk mode.
