“you mean, like, out of the toilet?!”time in the back
for single engine taxi
Eww gross, we're in contract negotiations "two engines till contract day"
Then you have the double punch EGPWS FOs (that’s a no), the Capt side ACP NORM to ALT during EGPWS test FOs, the guys who send the BARO and EOSID alt to the Capt side by using the display control switch both on R and back to norm (that one took me a while to figure out, I’d set my ND with the options I like, then notice I lost my airports and stations. It was because when they do that “technique” , it also grabs their ND setup).
What will they think of next?![]()
I don't know what double tapping the EGPWS test button does, or why anyone would do it? But the other things you mention, to include turning off the L recirc fan, I only know about because CA's are doing them. In fact, in my experience, exclusively CA's, since I don't do them myself![]()
Wasn’t there a memo specifically saying not to turn off the fans?I don't know what double tapping the EGPWS test button does, or why anyone would do it? But the other things you mention, to include turning off the L recirc fan, I only know about because CA's are doing them. In fact, in my experience, exclusively CA's, since I don't do them myself![]()
YesWasn’t there a memo specifically saying not to turn off the fans?
Because they don’t like the noise in the flight deck.why is anyone turning off the recirc fan for any reason, in normal ops?
like doing a manual standby power check in a Classic onward, and wondering why a fuse blew.
By the same token, if (by some miracle) the airplane is sitting with ground air hooked up, and the air is actually blowing cold, it doesn’t work nearly as well if someone has left the fan off.Well, since they pull air from the cargo hold tuning them off when the cargo doors are open in Las Vegas in July does help a little.
But our guidance says to leave them on anyways so enjoy the added warm air.
This is true, since it draws air from around the fwd cargo compartment. Watch the duct temperature if you aren't convinced. Varsity level technique is to turn the fan off, let the duct temperature get as low as it's going to go, then turn the fan back on to blow all that cool air from the duct into the cabin, rinse and repeat.Though lower pressure, turning them off does help the ground air actually blow cool instead of warm.
But I’m the type who just cranks the APU as soon as the walk around is done or the first passenger boards.
I run the packs in high on the ground all the time (Boeing calls it max cooling). Engine bleed switches off, APU switch on. The top row all in auto.Interesting. Have never noticed a difference in noise with the recirc fan on or off. Then again, the Classic only has one fan, so that might be the case. The Jurassic has a single gasper fan, which the noise of that thing can be heard.
It’s one reason I don’t use a pack to high on the ground when it’s hot outside, as that shuts off the one recirc fan and thus becomes a high workload for a pack with little net cold air gain. Operating a pack in auto and the recirc in auto when on APU, is better overall.
That shuts off the recirc fan (because engine bleeds switch are off), sets the packs to high (because engine bleed switches are off) and opens the isolation valve (because either engine bleed switch is off).
But that's an NG/Max thing. It's been many moons since I flew a classic and a decade longer than that since I last flew a -200.
