UA169 (VCE-EWR), aircraft or parts of it hit truck on I-95
I’ve seen that note on an approach as well. It wasn’t at BFI, but I’ve seen it.
This note is on quite a few approaches.
It's as simple as this...the electronic glideslope/glidepath will guide the aircraft to 1000 feet down the runway at a particular angle. The VGSI will indicate something different.
The VGSI may or may not have the same angle as the electronic guidance. They might both be 3.00 degrees, but if the VGSI is physically closer to the approach end (say, 600 feet instead of 1000 feet), the VGSI will guide the aircraft on a parallel and lower approach path.
In a few airports the VGSI is set up for a 3+ degree angle while electronic guidance gives a 3.00 degree angle.
Whenever I see this note, I specifically brief the point at which (or if) I will stop following electronic guidance and begin following the visual guidance because we know the two won't match up and the closer to the runway we get, the more pronounced the difference will become.
You … you people with your RAAS callouts as a text message on the ND. I can't hate that if only because its basically yet another angle to poke at Boeing for not putting an EICAS on the 737.
My favorite thing about RAAS is that we get some of the callouts (APPROACHING RUNWAY 34 RIGHT), some of them can be heard very quietly (on runway 16 left) and the rest you never hear (maybe they are super quiet and if the thing wasn’t so dang noisy in flight you’d actually hear the radalt countdown? Idk I’ve never noticed it on the JS either…)
  • Like
Reactions: bp
So you're saying there's a job opening?
United Airlines has issued a safety bulletin to its pilots after one of its Boeing 767s struck a light pole on the New Jersey Turnpike while landing at Newark Liberty International Airport on May 3, 2026.
The bulletin, identified as Pilot Bulletin 26-069 revision 1, was disclosed yesterday in the National Transportation Safety Board's preliminary report on the incident.
According to the NTSB, the aircraft struck a light pole on the New Jersey Turnpike during its final approach to runway 29. Debris from the pole then hit a tractor-trailer traveling southbound on the turnpike, an impact that was captured in video footage that has since gone viral. The truck driver sustained minor injuries.
The NTSB report also revealed what was happening in the cockpit in the final seconds before impact. The captain of United Flight 169 told investigators that he was aiming to see "3 red and 1 white" on the runway's Precision Approach Path Indicator (PAPI). The standard "on glide path" indication is 2 red and 2 white. Three red lights means the aircraft is below the standard 3-degree glide slope.
As the aircraft descended toward the runway, the first officer called out "airspeed slow" on short final. He then warned the captain, "hey you are slow," followed moments later by, "you are still slow and a little low." By the time he looked back outside and realized just how low the aircraft was, it was already about to touch down, and he did not have time to call for a go-around.
In response, United issued the safety bulletin to identify a hazard known as "ducking under," a pilot technique in which crews shift the aimpoint of electronic or visual glide path indications, contributing to low approach altitudes during the visual segment of approaches into certain airports and runways.
The bulletin reminded United pilots that all approaches must be conducted so that touchdown occurs no earlier than 1,000 feet and no later than 1,500 feet from the runway threshold.
The NTSB investigation is ongoing.
"Ducking under" should be left behind the day you enter a type rating ground school.
"4 RED, go around"
This should be a Resume Generating Event
Aiming point adjustment to the threshold at 200 feet RA was an approved technique for short runways on some fleets. It’s been a few years since I’ve operated a 767 that I’ve forgotten fleet specifics. However, nowhere will our manuals say to fly purposefully low. And this technique was also removed.
Why would there be a job opening?
A lot of intentionality there.
We have new training that deals with this. The FO needed to be more direct. “Add power, climb” and really “go around, airspeed.”
Not saying I would have done better, but this is the whole point of the training.
Still not usually how things work in the 121 world.
