Nerd out time!
Let me put my airport compatibility engineer hat on for a minute, since this incident made me go dig up some old manuals from a previous career. That note, and the TCH in general, can be very sneaky. The FAA has a Joint Order (6850.2B if you're curious) that specifies the minimum TCH for the PAPI approach path based on the eye-to-wheel height category of the aircraft, with applicable tolerances.
What this means practically is if you're flying a widebody or a 757 and see a TCH or a "VGSI not Coincident. VGSI TCH" of 59ft or less, your spidey senses should be going off, because you have much less margin than you think you do. In fact it's a giveaway that the approach is designed for small narrowbodies as the critical aircraft, so your operation is an outlier. At 50ft TCH on a 757/767 you'd only have 20ft of wheel clearance on path, and only 18ft on a 767-400.
On 29 in EWR it's right at 60ft, the lower limit for widebody operations. The -400 has 28ft of clearance on two reds and two whites.
Internationally it's a bit more tricky to calculate because in ICAO land, the Annex 14 recommendation is in terms of wheel clearance margin instead of TCH
But if we do the math backwards it ends up recommending the upper tolerance of the FAA brackets. So on my 757 it ends up being the same: 59ft TCH or less and I pay a lot closer attention.
