Roger Roger
Bottom of the list
Don’t yall have any enterprising guys 3D printing little hook things for em?Coffee stirrers work too. Or so I'm told.
Not anymore, since I've been here they have all been modified with the new ICS switch. They even did that to the classics that were still here when I started.Don’t yall have any enterprising guys 3D printing little hook things for em?
WITCHCRAFT!!!Not anymore, since I've been here they have all been modified with the new ICS switch. They even did that to the classics that were still here when I started.
The only NGs we have that require the rubber band are the 700s. None of the 800s or the 900ER do
There are also zero -800s that fly straight without copious amounts of trimActually….546 still has the flip flop radios. There are also 6 -800s that don’t have alternate destination function in the MCDU.
I call them Dash 800s because every time you move the power levers you need to re trimThere are also zero -800s that fly straight without copious amounts of trim
Fun flying with a former bus guy that’s droning around on vectors with like 3° of bank because he hasn’t touched the trim since top of climbI call them Dash 800s because every time you move the power levers you need to re trim
Also love the ones where the temp dial has to be cranked to keep from freezing everyone.Our 800s are a weird bunch. The “newer” ones fly all sorts of crooked. The older ones that got overhauled instead of retired because of MAX delays fly pretty darn straight and true,.
On top of being crooked, the guppy is just obnoxious to trim for some reason. Part of it is that the slip skid indicator is practically useless. The training department always tells you to just trim the rudder until the yoke is level but that only works if everything is dead straight. So instead you’re left going back to private pilot •-hold the wings level and watch for yaw. Trim out yaw with the rudder, then trim out any yoke force with the aileron. Repeat as needed.So strange to me. The Canabus pretty much trims itself and you don't have to mess with it at all.
Except for the speed trim.
We have to manually speed trim it. If you ever listen to one of our CVRs on climbout, you'll hear the regular required callouts and every couple of seconds "click-click........click......click-click....." as the PF brings the speed trim in line with the speed.
The guys who come over from the 320 absolutely hate it.
*Laughs in MD-80*Also love the ones where the temp dial has to be cranked to keep from freezing everyone.
737 FO adjusting climate control and trim in an -800 on climb out (2026, colorized) [yes I know the PF shouldn’t generally be messing with the climate control]
