Roger Roger
Bottom of the list
View: https://x.com/Mikels_money/status/1985847022667137254/video/1
Another angle in the top left pane, it doesn't appear they ever fully got off the ground.
Sumbitch did not want to fly
The justification for EMAS is usually inadequate RSA or RESA, often as a result of a road or terrain versus a populated area.
I can’t imagine how much EMAS would be needed to stop a loaded MD-11 at Vr speeds.
Going way back, AA191 (a DC10) had an engine separate and take part of the hydraulics with it, causing the left wings slats with it.
Is that a possible failure mode with the MD11?
A laundry list of CF6s have failed spectacularly over the years, of course most famously UAL232, and fairly recently an AAL 767 in ORD which ended in an abort right before V1 and the aircraft burning very substantially.Going way back, AA191 (a DC10) had an engine separate and take part of the hydraulics with it, causing the left wings slats to partially or completely retract.
AA191 was a Mx error on engine replacements that AA had created that wasn’t endorsed by McD, that caused the failure of that engine pylon. Had nothing to do with the DC-10 itself, but the NTSB screwup during the investigation made it appear it was the DC-10 design deficiency, which it wasn’t.. Something the DC-10 didn’t deserve
I am well versed in the accident, thank you.
But you missed the question
Can a catastrophic engine failure disable the hydraulics in a similar way?
Obviously we know very little but it’s the kind of thing that would leave a large chunk of nacelle on the runway and cause a spectacular fire on the wing. One does wonder what else was damaged that the aircraft wouldn’t lift off with 2 operating engines, and in that respect may have some similarity to AAL 191
Jeebus. That’s awful.From a post on reddit. It appears the entire engine is resting on the side of the runway. reddit
Losing an engine AND left side controls is .... tragic.
A lot of that MX error was also due to leaky hydraulics on a forklift and a shift change.That accident changed MX, it happened long before my time but the changes made are still in place regarding shift turnovers and following the AMM rather than having an in house method approved by the company because it's more expedient.AA191 was a Mx error on engine replacements that AA had created that wasn’t endorsed by McD, that caused the failure of that engine pylon. Had nothing to do with the DC-10 itself, but the NTSB screwup during the investigation made it appear it was the DC-10 design deficiency, which it wasn’t.. Something the DC-10 didn’t deserve
The other thing that killed 191 was their speed, specifically their reduction in speed following liftoff. They had some excess speed, which was unknowingly compensating for the missing LE devices on the left wing. Following their training, the crew slowed to the climb speed they were trained to go to, which unknowingly, was where the asymmetric lift could no longer be compensated for. Of course the training was changed after that.
Is that the origin of V2 - V2+10?
I met him a handful of times. He was a class act. They will be missed.He was currently the #1 MD Capt. I would’ve been #2 behind him. Great guy! Well liked and very experienced! RIP…![]()
The other thing that killed 191 was their speed, specifically their reduction in speed following liftoff. They had some excess speed, which was unknowingly compensating for the missing LE devices on the left wing. Following their training, the crew slowed to the climb speed they were trained to go to, which unknowingly, was where the asymmetric lift could no longer be compensated for. Of course the training was changed after that. Point being, even with that damage they incurred in that incident, the jet was still flyable with the speed it had attained.
Lots of variables in any of these events.
Curious if the right engine was producing full thrust. Or if it was potentially damaged in some way such as FOD. Ie- did they really have two remaining good engines. FDR will reveal.
Also kind of my point. I'm guessing the crew is very familiar with AA191
Looks like the PF is using extra runway to get extra speed to get extra control (more air over remaining control surfaces).
If they rotated and sensed insufficient roll control, then delayed any additional rotation.
As for #3 not producing 100% power:
I've seen 1 low slung engine pop and take out the low slung engine on the opposite side, twice.
One was a 737 and one was a 767.
Note: I cannot see any evidence on the video to support that.
