Eastern Airlines - May 2025 Thread
Looks like it is, you do preflight planning and dispatch releases while also watching other things like crew duty etc according to the job post
Sir,
The link you provided is for a Dispatcher position, not flight follower. Not sure where you are seeing the Flight Following title.
Thanks Sir
Absolutely no need to be a smartass in this forum when someone is trying to help posting a job(s). Doesn't matter if someone doesn't post both links, do a little research if they say the same company has two different positions open.
Sir,
Ok. Apologies.. was not trying.. was confuse on link and title.
Thank you Sir
Eastern operates two companies under the same holding company. EAL and EAX. EAL has both 121 supplemental and flag authorizations on its certificate. It therefore needs dispatchers (operational control with PIC). EAX is a 121 supplemental and does not need dispatchers, so it hires flight followers (Dir of Ops has ops control, delegated to flight follower).
Sir,
Thanks for the explination. NiCE to see not everyone here is rude like that other gentlemn.
Steer clear of eastern airlines if you can help it. You would be better off working at a regional for less pay. They were a good airline to go to before they moved to Kansas City. It has gone downhill in the last year.
I'm sure its not hard to guess why, but could you explain some more?
I've heard the same thing from people who know employees, they said its real crap show over there.
