Well it's already being blamed on DEI on PJP so....
Off to go take some more notes!
Case closed, wrap it up, boysWell it's already being blamed on DEI on PJP so....
that place is a cess pool of cultists...the Courseys would kill their kids if Mike Lindell said soWell it's already being blamed on DEI on PJP so....
Skrrrrrt!
Skidmarks into the turn is not a good look. Rumot is they tried to make the 90° while going 25 kts and asked ATC if they could roll to the end and that they will “keep the speed up”.
www.koin.com
And
More concerns as Alaska Airlines flight arrives at PDX gate with open cargo door
Alaska Airlines is facing another round of safety concerns after a flight arrived at the gates at Portland International Airport with its cargo door slightly ajar.www.koin.com
I mean do these morons realize the chance is pretty high that if it was maintenance related it is much more likely it was done by a middle aged angry white dude like themselves?Well it's already being blamed on DEI on PJP so....
Have you ever worked on airplanes? At the last few places I've been employed your uninformed ideological based opinion is far from reality. Young, old, any color, any gender, none of it matters because it's a meritocracy. All that matters is if a person can do the job effectively and take complete responsibility for their work. If you're a passenger or a pilot are you concerned more about who did the work or whether it was done correctly?I mean do these morons realize the chance is pretty high that if it was maintenance related it is much more likely it was done by a middle aged angry white dude like themselves?
Oooooo, don’t let ATC fly your airplane
Doesn't help it when it landing almost 200k under design limit. Or taking off under 200k, for that matter.Pavement looks wet. Those Runway Threshold white stripes abeam the taxiway get very slippery when wet. The Mad11 was very susceptible to this just simply taxiing onto the runway for takeoff at a slow speed as the front tires struggled for traction. Basically had to treat it as an icy/cluttered condition with differential braking and thrust.
Once in SDF after landing in the A300 I tried to exit a high speed at a somewhat “spirited” speed trying to help the guy behind us. Everything seemed fine until the tower asked if we needed assistance? We asked what he meant and he told us he saw a lot of white smoke from the nose tires as we exited….oops! Lesson learned.
He clarifies in this one that his recording missed the initial ATC instruction to keep their speed up until the end. Looks like they missed the high speed. It has video of the turn, not just the aftermath.
View: https://youtu.be/ryS6w9b6OlE?si=Wm3gh9eOW1OAvkvK
Fixed it for ya!Pavement looks wet. Those Runway Threshold white stripes abeam the taxiway get very slippery when wet. The Mad11 was very susceptible to this just simply taxiing onto the runway for takeoff at a slow speed as the front TIRE struggled for traction. Basically had to treat it as an icy/cluttered condition with differential braking and thrust.
Ignore this.
United plane engine catches fire midair, flight turns back to Houston shortly after takeoff
The engine caught fire after United Flight 1118 took off from George Bush Intercontinental Airport. The plane was headed to Fort Myers, Florida.www.usatoday.com
View: https://twitter.com/jboulah/status/1764825936954823096?t=Ec8-SIC8vMONcJ-z9OSiAQ&s=19
This also happened
