trafficinsight
Maybe the aircraft has strong feelings about the definition of what is a sandwich?
Easy there Che...
The proper response to this is “K”If I recall well, sometime last year a private citizen was ordered to take down his "legal" webcam that was trained at some military facility. It was done based on National security.
"The B-1 is a conventional supersonic bomber"
"Conventional" eh?![]()
Regards security, many air bases have things on the ramp that can easily be seen from outside the perimeter fence. For example, the E-4B Nightwatch NAOC jet sits on APU power on the ramp at DMA when AF1 is somewhere in the western US. It can easily be seen from the junkyards across the runway and just outside the perimeter fence, not more than 800 yards or so away. Hell, if someone was going to do something nefarious, it could probably be done. But, that’s how it is for such a large aircraft and the base layout.
Does the night watch always trail AF1? I should probably know this, but have never paid attention
You took that way too seriously. Especially in the context of a civilian article. Using the normal definition of "conventional" the B1 is far from that.Completely.
Part of the START treaties it lost that mission. It did for a while carry the widest array of conventional ordnance and select ability within that payload over the other bombers so it had a menu to chose from when a B52 would typically only be carrying 1 flavor of JDAM on the wings only.
Similarly the Russians took air refueling out of the Backfire, though it’s arguable how quickly that could be put back on. Either way I’d love to see the result of somebody trying to probe refuel a bomber having 0 days of training in it so it’ll be fun if they tried.
At least he touched the runway!!!
It does, but zero-zero seats are just that….zero-zero. If your low altitude and with a significant roll angle, rate of descent, or both, you could easily be outside the seat’s envelope of success. The seat does its best to solve the puzzles of the parameters it’s given at the time of ejection, but it only has the power to solve so much.I'm curious where they punched out - will the B-1 allow for a 0-0 ejection, or is it one of those "you can do anything ... once" type of things.
Drop an F in the chat for our boy gooseI actually saw this once; it was an F14 in a flat spin. The plane was spinning rapidly when the eject was pulled and for some unexplained reason, the departed canopy continued to spin just above the plane in harmonious synchronization. The result is that the rear got his head slammed into the canopy.
Unfortunately he died!![]()
I think that part of the script was actually based on a couple of true stories with lots of facts mixed up for dramatic effect. Or not.I actually saw this once; it was an F14 in a flat spin. The plane was spinning rapidly when the eject was pulled and for some unexplained reason, the departed canopy continued to spin just above the plane in harmonious synchronization. The result is that the rear got his head slammed into the canopy.
I didn't say any of it was or is common, I just said the writers/producers took pieces of several different real incidents and blended them into a dramatic, fictitious scene for the big screen. Every part of that story actually happened, they just didn't all happen at the same time. When I was 15 watching that movie I thought to my 15 year old self "Who would want to fly in the back seat of an F-14?". So I'm a mechanic on shore. The effect for recruitment was off the charts. I was an old fart at 5, I thought "Nope". I'm entirely uncertain whether or not I made the right choice.Yeah, there is a long history of departure from controlled flight in just about every legacy fighter community. Tomcat had the flat spin mode, Hornet had the "falling leaf" departure. I'm not sure if it was fully resolved in the F-14, but they mostly fixed the glitch with software in the F/A-18. I know the F-16 has had its share of inverted deep stall/spins as well, for which they also developed a creative "fix" eventually. We brief "Departure/Spin" boldface procedures prior to every ACM flight, for this historical reason, though unrecoverable departures/spins are a lot less common today. But it would probably be an understatement to say that they were common in 1985/1986 as the film was being made.
I think the agreed upon fix for the Tomcat was getting rid of the TF30…. And then retiring the jet.
Problem solved.
Interestingly, the Iranians have never had the issues with the TF30 to the degree that the USN did and have managed to keep it in service well. Likely due to learning from the USNs experience with them, and with the substantial parts package they did receive for them. Interesting bit of info though.
