Awesome man thank you very much!S&S Aviation at CNI are as good as they come, give Jimmy Garland a call and he can either help you/get you in touch with someone he knows can.
Jimmy used to do all the work on the 414 I used to fly.
Says Richard L Collins jrPrebuys are getting hard to come by. A lot of shops are too busy for last minute work, and honestly, don’t want to be inserted into the middle of a deal that could go bad.
Last purchase I did, I paid to fly a guy into town, and made arrangements to have hangar space & jacks available.
That said, I’d try to focus on a shop that is an expert on your type. What’s good for a 182 might not be the best thing for a 210.
An annual isn't a pre-buy either. It's a start, but you really need to tell the shop what you want looked it. Everything isn't a airworthiness issue. Worn-out tires, soft wing walk, failed radios, low compression, internal engine rust and corrosion will pass an annual.Another detail is that there is no standard pre-buy. It is not a FAA required inspection. Therefore, a lot of discretion, the technician can look as deep as you want, or as little. Unless you are truly combining it with an annual or condition inspection.
