Cherokee_Cruiser
Bronteroc
Pilots of 777s and 787s warned over pitch-guidance mode slip before take-off | News - Africa Pearl
US safety authorities have cautioned Boeing 777 and 787 operators over a potential mode confusion during take-off which can result in the aircraft departing with the wrong pitch-control guidance. Incidents have been recorded in which the ‘altitude hold’ mode of the autopilot flight-director...
africapearl.com
Reading through this, it sounds like the Emirates 777 scenario out of Dubai.
But again, no takeoffs are automatic. Pilots takeoff manually. So assuming you liftoff successfully by pulling the yoke and aiming for the 15 deg line (MOST part 121 jets for initial pitch until about 1,000 AGL), there should literally be no problem. All that happens is the flight director captured altitude hold mode close to airport elevation, and now the pink magenta bar "tells" you to lower the nose to level off. You should NOT get any "don't sink!" warnings, unless you physically pitched the nose down after takeoff and start descending.
Is this *literally* telling pilots to please not follow the magenta magic and start pitching the nose down just moments after takeoff?
"Why did you push the nose down nose down to level off just seconds after liftoff?"
"Well, because the pink line was telling me to!"
I want off that jet. Now.
