Regardless of your skin color, does turning the AP back on while trying to manage a trim failure/fault makes sense to anyone here?
This part was tough to watch. Haven’t finished the show yet, but yeah, Boeings handling of this whole thing was always my biggest problem. I have no love for the 737 beyond the 400 series. That was as big as it should have been. Now it’s a damn taffy pull of a plane on stilts.
Ahh, OK. Thank youNo. But turning the AP on (and assuming it stays on because it was properly in trim and the autopilot can be engaged) would disable the firing of MCAS. MCAS only fires in manual flight.
That said, this was not their goal of trying to put the AP on. It looks like it was a scripted move to put the AP on.
Ahh, OK. Thank you
I misunderstood the sequence. I understood that the AP was on, they started having problem, took over manually and retrained while fighting the controls, then turned it back on. When they did this, the plane nosed over.
(This all from prelim so it’s probably old news)
And also thankfully, why were there no crashes here in the states due to MCAS?
From the prelim report AFTER the stab trim cutout switches to cutout:
“ From 05:40:42 to 05:43:11 (about two and a half minutes), the stabilizer position gradually moved in the AND direction from 2.3 units to 2.1 units. During this time, aft force was applied to the control columns which remained aft of neutral position. The left indicated airspeed increased from approximately 305 kt to approximately 340 kt (VMO). The right indicated airspeed was approximately 20-25 kt higher than the left.”
That is clearly a nose down trim. So my question is, was it aerodynamic forces which caused the stab trim to go from 2.3 to 2.1 units nose down? Or, is it the worse case: the FO actually spun the wheel the wrong direction?
I still haven't seen the documentary but plan to with my wife.
Lion Air I can understand because it was the first. The Ethiopian is harder to understand. They knew about MCAS by then, they knew how to stop it - including flaps out of 0. They could have done a few things to make sure they didn't crash. For Ethiopian, the crew experience absolutely came into play in terms of outcome. They should have known about MCAS and handled the situation properly.
No, the kid got it right quote was cut off. Right after that, in my head cannon, he said "but the captain? Jesus!" Editor had a bunch of people talking at once after him and they rejoined with his words at the end. Watch the docu-drama again. One narrator references the aoa as an engine instrument. They drop the audio some and they erased reference to it in the captions, but that was a fairly bad job done.Oh, and I thought the piece did a tremendous job with how they covered the overt racism layered over this. They didn't explain it - they just gave it a medium to build on its own with the story. You walk away from that documentary with an understanding of the perception that Thai/Ethiopian pilots were inferior when compared to American pilots, and this was the first place one should look. I don't think the same accusation would be made of a German pilot.
That line from the obviously emotional AA pilot ... "the kid got it right and they still crashed" was moving.
"U.S. jury finds former Boeing 737 MAX pilot not guilty in fraud case
By David Shepardson
March 23 (Reuters) - A jury in Texas on Wednesday found a former chief technical pilot for Boeing (BA.N) accused of deceiving federal regulators evaluating the company's 737 MAX jet not guilty, court records showed.
Former Boeing pilot Mark Forkner was indicted in October on charges of scheming to defraud Boeing's U.S.-based airline customers to obtain tens of millions of dollars for Boeing.
The government alleged Forkner deceived the Federal Aviation Administration during its evaluation and certification of Boeing’s 737 MAX airplane.
Court records and a spokeswoman for the U.S. Attorney's Office in Northern Texas confirmed Forkner was found not guilty on all counts.
David Gerger, a lawyer for Forkner, in a statement praised the "independent, smart, fair judge and jury." The FAA and Boeing declined to comment.
Forkner, who had faced up to 20 years in prison on each count, maintained his innocence.
The government had alleged Forkner provided the FAA Aircraft Evaluation Group with "materially false, inaccurate, and incomplete information" about a new part of the flight controls for the Boeing 737 MAX, called the Maneuvering Characteristics Augmentation System (MCAS).
MCAS was tied to two fatal 737 MAX crashes that killed 346 people but the government noted it did not charge Forkner "with causing the crashes of Lion Air Flight 610 or Ethiopian Airlines Flight 302" and did not argue he caused them.
Prosecutors pointed to one message Forkner sent to a colleague in which he said he "basically lied to the regulators (unknowingly)" about MCAS.
A judge dismissed two fraud counts in February related to MCAS saying the two charges could not proceed because they must involve a tangible airplane part.
Boeing in January 2021 agreed to pay more than $2.5 billion in fines and compensation after reaching a settlement with the U.S. Justice Department over the 737 MAX. The deferred prosecution agreement included a fine of $243.6 million and a $500 million crash-victim fund over fraud conspiracy charges related to the plane’s flawed design.
The two crashes cost Boeing more than $20 billion and led to the plane's 20-month grounding that was lifted in November 2020.
The Justice Department said the crashes "exposed fraudulent and deceptive conduct by employees of one of the world’s leading commercial airplane manufacturers."
U.S. House Transportation Committee Chair Peter DeFazio said in October that Forkner's indictment "should not be the end of the accountability for this colossal and tragic failure" and argued "senior leaders throughout Boeing are responsible for the culture of concealment that ultimately led to the 737 MAX crashes."
Forkner is the only person criminally charged to date in connection with the MAX."
A Texas jury on Wednesday found a former chief technical pilot for Boeing not guilty of deceiving federal regulators who approved the company's 737 MAX jet which later was involved in two crashes that killed 346 people.www.reuters.com.
Another case of white collar crime going unpunished.
"Hey babe, I know weve both been busy for awhile, whatd ya say we hire a sitter, and just have a nite to ourselves, make a little dinner, some popcorn and watch a netflix documentary on how the airplane I fly could potentially turn against me and try to kill" ....You ladies man you!I still haven't seen the documentary but plan to with my wife.
Do apostrophes work on whatever device you posted that from? Or were you just in such a hurry to post some line you think is funny and gave up on punctuation?"Hey babe, I know weve both been busy for awhile, whatd ya say we hire a sitter, and just have a nite to ourselves, make a little dinner, some popcorn and watch a netflix documentary on how the airplane I fly could potentially turn against me and try to kill" ....You ladies man you!![]()
B. And the phrase I have in mind for you requires no apostrophes at all!Do apostrophes work on whatever device you posted that from? Or were you just in such a hurry to post some line you think is funny and gave up on punctuation?
?. I'm confused. Say what you think about me or anyone else, what do you think you're hiding behind and, more importantly, why are you hiding what you truly feel?B. And the phrase I have in mind for you required no apostrophes at all!
The fact the jury took only 2 hrs to deliberate and come back with not guilty is telling. I’ve maintained that everything Forkner wrote in his emails and demanded from those below him were basically direct orders from those above him. Nothing but a scapegoat here.
Wasn't this the guy that Boeing is trying to scapegoat?
