Pilot Fighter
I just want to know when we’re going to start seeing some HARM’s slung underwing.
What are the hiring mins for WSO's?
AN/ALE-39 is most effective at airshows and Tiger cruises.The first jet that takes off with the system in auto, and catches sun glare reflections from windows of parked cars or buildings and starts kicking out its program cocktail. Haven’t seen that before…..![]()
Tell that to my car!Heat seeking is so 1970s. No reason a modern camera and processing package couldn't track and guide visually.
@Pilot Fighter just place the airline name below the insignia…..
View attachment 62933View attachment 62934
The flares were pretty. Also, if the • hit the fan, you pretty much had to dump everything as it was unlikely you would trust the load out. Was that flares or chaff on the right?Lol I did my first deployment into AFG with that garbage. I think they rolled off the line in like 1970. So good....not that it mattered there, for us
A..P..R......39.......operational. Or better yet giving the guys up front a yoke switch to deploy an event. Same result but now there is someone to blame.The first jet that takes off with the system in auto, and catches sun glare reflections from windows of parked cars or buildings and starts kicking out its program cocktail. Haven’t seen that before…..![]()
Were you a rotorcraft guy?A..P..R......39.......operational. Or better yet giving the guys up front a yoke switch to deploy an event. Same result but now there is someone to blame.
As for the load, yeah we had to manually set this little mechanical counter wheel thingie between your legs/feet, based on whatever you counted on pre-flight.
On the Hog, we had 16 slots for 30-count boxes per slot, assuming 1x1s loaded per box, for a total of 480 1x1s. Could do all chaff or all flare, but generally was 240 of each, flares on the inboard boxes and chaff on the outboard boxes. Unfortunately to set the ALE-40 settings, they were inside a door on the left exterior of the jet near the lower aft part of the canopy. So, if you failed to check/verify it before takeoff, you got whatever the weapons people left it at last.
Yeah all our release programming settings were manipulated on a box with mechanical wheels that was behind the ejection seat down in what we called the "hell hole"....no ability to adjust it after strapping in. Luckily we got rid of all this nonsense with ALE-47, which is the entire fleet at this point (other than a few non-operational Hornets still flying).
I want to say it could be either, but it has been a while....we also only had 2 buckets rather than the 4 on the E/F/G, which was limiting. They also had a bad habit of uncommanded release of expendables in the F/A-18 for a while.
on the F-117, we had nothing. No chaff, flares, or ALE/ALR. In theory, we shouldn’t need them. In theory. But also, there would be nowhere to install them, that wouldn’t affect the RCS.
Remember to turn off the lights and hope for the best.
