Roger Roger
I am le tired
I think in context he’s referencing when things go badly out of balance. Helicopters are weird man.I know very little about helicopters.
Is that mostly due to hard landings? Where do you get structural damage on helos?
Props are for boats........
I'm somewhat surprised they use wood in composite props on something like that.
Composite prop technology is pretty cool. The stress and loads can be tremendous in one plane and minimal in others. I’ve seen them damaged from something as simple as a shirt collar getting snagged on a blade while pulling chocks from the nose wheel, yet they can endure significant loads during aerobatic flight, including gyroscopic maneuvers. Some C-130s, Convair, Douglas and such have aluminum propellers but most larger post-war propellers are composite, mainly due to weight and in field (on-wing) service. MT Propeller has a big presence in this market, they make composite fixed pitch propellers for 100hp applications to Cirrus & Extra and all the way up to large 7 blade applications.
Even with dampeners in various places, helos constantly suffer from vibration issues with how they operate, some more than others, some less than others. For the longest time, UH-60s for example, had fuselage cracks developing just from normal airframe vibration, around the forward upper part of the gunners windows….frame 133 if I remember right. When those would get repaired and reinforced, those vibrations would migrate to the next weak point on the airframe, which turned out to be the transmission mount points on the roof deck area of the helicopter. It’s one of the reasons everything is life limited in some way on a helicopter.
Interesting.
And....dampeners.....they get it wet? :-D
Always amazes me that I can turn the props with a fingertip on the free-power-turbine Pratts of various sizes - that's not to say that neither the 14RF9 nor the Hartzell are light (they aren't), but the balance is pretty neat to behold. Amazing materials meets precise balancing, manufacture and overhaul.Composite prop technology is pretty cool. The stress and loads can be tremendous in one plane and minimal in others. I’ve seen them damaged from something as simple as a shirt collar getting snagged on a blade while pulling chocks from the nose wheel, yet they can endure significant loads during aerobatic flight, including gyroscopic maneuvers. Some C-130s, Convair, Douglas and such have aluminum propellers but most larger post-war propellers are composite, mainly due to weight and in field (on-wing) service. MT Propeller has a big presence in this market, they make composite fixed pitch propellers for 100hp applications to Cirrus & Extra and all the way up to large 7 blade applications.
www.instagram.com
MTs are really popular in the EAB community. They've given Hartzell a real run for their money lately.
Also - there is a terrific YouTube series about all the stuff a prop goes through on overhaul. Fascinating:
I concur. In a previous life I did NDT for a propeller shop (FAA repair station). If anyone flies propeller airplanes and hasn’t visited their local prop shop - I highly encourage it. All kinds of voodoo and sorcery happening.
Also, Hartzell had a similar problem to the original post with their steel hub systems, including at least one blade separation that penetrated a Commander 500 fuselage and killed someone.
Which is why we all must pay the Hartzell AD tax, otherwise known as the Prop Shop Protection Act, every so often.Also, Hartzell had a similar problem to the original post with their steel hub systems, including at least one blade separation that penetrated a Commander 500 fuselage and killed someone.
Was that the issue with the ALUMINUM hub that has the 100-hour AD now? I wasn't aware of an AD related to steel, but on a Commander might be a completely different prop hub.
I don’t know that I’ve seen a compact hub that still had the 100 hour AD since ever. I assume they’ve pretty much all been replaced.The Hartzell steel hub has a completely different retention system, the blade was on a spindle like component and steel clam shell style clamps to hold it. Those steel blade clamps where prone to cracking at a specific groove. Hartzell then modified the clamp, called it the MV style - but that still wasn’t crack free. The blades, piston, cylinder and a couple other small items are aluminum but the majority of the assembly is steel.
The new aluminum hubs or “compact” hubs clamp the entire assembly, including the blade butts. In this assembly, only the bearings, hardware and a couple small items are steel, with the majority of the assembly being aluminum. The 100 hour eddy current or “A” hub inspection is due to cracks propagating from the grease fittings. This boss was changed and moved on the “B” hubs to eliminate the eddy current inspection and AD.
Thanks!
I have the A-compact hub.
Sent from my iPhone using Tapatalk Pro
They’re fading out of service, slowly but still some owners see the ET inspection as a lower cost alternative to overhaul & replacement. I’ve been out of the NDT business for a little while, so I don’t know what the inspection rates are going for these days. Eventually the liability will be high enough that the 100 hour inspection won’t be cost effective anymore.
