Pretty neat, huh?I'm somewhat surprised they use wood in composite props on something like that.
You wanna ride it all the way down or be the first one to take a nap?Bad day. Lesson learned; never sit abeam the props.
I'm quite impressed that the airplane is in that good shape for losing most of a blade.You wanna ride it all the way down or be the first one to take a nap?
Southwest Airlines has entered the chat
Yeah, I’m merely more accustomed to the loss of a blade resulting in a collision with terrain, which does not look good from the outside.It would be interesting to see what if any sensor recordings have to say about that.
There are a lot of looks good from the outside helicopters that have severe structural issues or need complete change out of parts well before TBO, but from the outside they look fine.
Or an engine deciding to part company from the airframe.Yeah, I’m merely more accustomed to the loss of a blade resulting in a collision with terrain, which does not look good from the outside.
I read a story about one on a Beech 99 in Alaska where the engine separated from the mounts after that, but stayed attached by the hoses and cablesOr an engine deciding to part company from the airframe.
Yeah, those hoses and cables are pretty tough. This picture is of a Hawker (shudder) that got hit by a heat seeking missile, if you look closely the only things left from the TFE-731 still hanging on is the gearbox with the alternator, starter/generator and hydraulic pump still attached and what I think is the oil tank? Whatever that rectangular object is it's blocking the view to determine if the fuel pump/control and the oil pump are still there, I can't think of anything that would've kept the oil tank attached but there it is.I read a story about one on a Beech 99 in Alaska where the engine separated from the mounts after that, but stayed attached by the hoses and cables
Everybody walked away AND a Hawker got totaled? Seems like a win!Yeah, those hoses and cables are pretty tough. This picture is of a Hawker (shudder) that got hit by a heat seeking missile, if you look closely the only things left from the TFE-731 still hanging on is the gearbox with the alternator, starter generator and hydraulic pump still attached and what I think is the oil tank? Whatever that rectangular object is it's blocking the view to determine if the fuel pump/control and the oil pump are still there, I can't think of anything that would've kept the oil tank attached but there it is.
