CFI A&P
Exploring the world one toilet at a time.
I seriously doubt that You have ANY prior military service under Your belt.
What prize do we get for proving you wrong ?
CI. Cost Index. Basically, the most efficient way to fly a big jet to meet a certain goal on the speed vs. cost matrix. Clear as mud? It's programmable in all Boeing boxes I'm aware of, and I would guess Airbus has some analogue that's the same thing but has a different name because Airbus is French Oh-ho-ho-ho. Would try to help more but for obvious reasons I have the evident OP on ignore, so.
i have no idea what CL numbers are or what they do, being a mere ppl holder. Can you explain it to me in layman’s terms?
People have done a crap job explaining this.
CI 000 means that the cost per hour of a crew is very cheap, and the cost per hour of fuel is very expensive. Because of that it makes sense to fly at the most efficient fuel burn airspeed (slow) , even though it keeps the crew on the clock much longer and racks up more wage costs.
CI 999 (not 100 like our resident clown insinuated) means crew costs are of the highest concern, and fuel is cheap. This means it makes sense to fly as fast as possible to minimize the amount of time the crew is on the clock, even though it burns more gas.
Every flight is dispatched with some number in between, which the FMS then crunches to generate a speed to fly. You can have different CI numbers for climb, cruise, and descent. We only use a cruise number, and it's generally between 0 and 20. If we are running late and passengers have connections, or the plane needs to go right back out, we get in the 100 to 200 range.
Of course crews are mostly guaranteed the scheduled time for a flight, so a higher than normal CI number doesn't generate wage savings for that specific flight. But over a long period of time, high CI number operated flights average together and generate shorter scheduled times.
Yes we regularly see cost indexes of 500 at my employer… my highest personal CI assignment was 800 but we had been delayed about 12 hours.Simple... Everyone should know this enter "0" the ship should slow down... Enter "100" the ship will speed up. From My experience CI is governed by fuel prices anyway. Does Your carrier instruct You to dial in .300?
It appears that Your carrier uses a CI of .999? Is that what You are saying???? AMAAAAZING...
First of all it isn’t .999… it’s just a whole number ranging from 0-999. Second, he was explaining it for the people who don’t know not just aimed at you so could you knock it off with the sarcastic pettiness? @BobDDuck didnt attack you so why respond in that manner?It appears that Your carrier uses a CI of .999? Is that what You are saying???? AMAAAAZING...
I didn’t really care, I just wanted to see if the troll could actually explain it
Kenya Airways Under Fire From Pilots For Flying 787s Too Fast
simpleflying-com.cdn.ampproject.org
Yes I agree... This HAS to be illegal. I wonder if they have somehow managed to disable / bypass the audible overspeed warning. 10 hrs or more of that would be nerve wracking at best...
How about you just worry about finishing up that private pilot certificate.Sitting here biting My finger trying not stoop to Your level...... 1 one thousand ..... 2 one thousand....
How about you just worry about finishing up that private pilot certificate.![]()
Have you ever input your own cost index numbers to see how it affects your speeds?
What do you fly again?
Question #1: I plead the 5th
Question # 2: The proverbial "Toyota Corolla" of the aviation world. (Or BMW 3 series) depending if any bus devotees are present..... Then the aforementioned Corolla designation slides down the scale to them.
