...is a much slower process than I imagined. Lots of “hey you’re gonna drown bro” sirens while the doors close and fans shut off.
I wouldn’t want to be the person cleaning it up, that’s for sure. @MikeD can you wash this away or does it have to be disposed of in some special way?
Didn’t CBP have a hangar-full of helicopters covered with that a few years ago?
By the time the door close, the fire will have burned that place down
Fully two minutes before foam even starts. In a hangar full of fueled up airplanes, everything is probably a total loss by that point.
What are the odds the fire burns through the suppression system before it even has a chance to do its job?
Just stick a bunch of those raver kids in there. They like foam parties.Life safety comes first. You give people, in this situation, time to GTF out. Buildings and aircraft can be replaced. You could actually walk through this, if need be.
You SURE don’t want to be stuck in a server room when Halon dumps for an electrical fire, though.
But can I evac with my carry on bags with me tho?Minimal.
The timing is about life safety, not property protection, in a building of this size.
The goal of your home smoke detector is to get you the hell out of the building, NOT to save your personal belongings or house. Home sprinkler systems could more probably do both, but few people have them. You have a house fire, your goal is to live (with your family) - it’s NOT to save replaceable items, however important they may be personally, in a situation where (literally) seconds make the difference.
A water sprinkler system won’t make much difference if Jet-A, or even 80 octane gasoline is involved. You need foam to contain and extinguish. Foam both limits visibility and is slippery in which to run; hence, the time for evacuation - because human life always trumps the loss of replaceable property and “things.”
Was that some kind of test event? What did I just see? Not to mention, if the foam didn't descend directly upon the burning airplane/airplanes, what the hell is the point? A hanger with a floor full of foam while the hydrocarbons in the wings of the planes above the foam continues to be fueled by oxygen which continues to convert the hydrocarbons into CO2, H2O and crispy stuff?...is a much slower process than I imagined. Lots of “hey you’re gonna drown bro” sirens while the doors close and fans shut off.
They only test the system for a bit, then shut it off, hence the tarps around the edges to keep the cleanup to a minimum. It's designed to fill the entire volume of the hangar. I've seen it accidentally discharged in both hangars of a major pharmaceutical company, a few G550s and S76s with their doors left open on a holiday weekend... $$$Was that some kind of test event? What did I just see? Not to mention, if the foam didn't descend directly upon the burning airplane/airplanes, what the hell is the point? A hanger with a floor full of foam while the hydrocarbons in the wings of the planes above the foam continues to be fueled by oxygen which continues to convert the hydrocarbons into CO2, H2O and crispy stuff?
the best thing about working for the gov't is you still get paid when this happens. Private companies either shut down or tell you to go home till they call you.
Concentrated aircraft dissolve, water, and air.What is the foam made of?
