Toughest things in a dispatchers shift
I may have made dirt for money, but I'll be damned if I ever went near anyone else's food. That's a cardinal sin.
It got so bad where I was at they had to put security cameras in. The offender solved that by turning the cameras to the corner.
While this went off the rails early, for me it would be any combination of:
-Reroutes after push
-En route holding
-2+ hour taxi delays
-Having enough time to think up inappropriate jokes
-Terminal constraints
-Wondering how long the line is at Wendy's
-Knowing how long the line is at LGA
Yes, but you can always order delivery online through the Domino's website or GrubHub while it's happening. Dispatchers are good at multitasking!
I recently discovered DoorDash. Big leap up from GrubHub.
When someone from scheduling volunteers to pick up something that’s outside of the inner circle of regular delivery places, it’s a good day.
-En route holding
Extra hold fuel is for when the dispatcher leaves to get food, right? At least that's how I interpreted the regs.
I think he means when it happens for everyone and not just on his computer.
But... you don't get stuff done. You're sunk. Depending on the source of the failure, someone has to fix it before you can send a flight plan or an amended release (depending on the nature of the amendment) if a flight has blocked out but did not take off. Unless specifically authorized by the FAA (very very very rare anymore for scheduled commercial passenger operators, if any at all) you're not allowed to operate by a flight plan calculated by hand.
You rely on the remaining resources you have to maintain operational control where you can and if it stays down long enough, your airline makes the nightly news because of delays throughout your entire flight network since they can't get a flight release.
You take calls from everyone, everywhere who can't pull up release information and tell them all the same thing. They may ask if you've rebooted your computer. They want you to tell them when it's going to be fixed when you have no idea. As more and more calls come in asking the same thing, you try not to berate them for asking questions you can't possibly answer.
Then your relief shows up. You've never been so happy to give a passdown. Then you go home and drink after your shift ends.
