Larry Page's Self-Flying Taxi Set for New Zealand Test Runs
RDoug
So it's got rotors for vertical lift, a wing for lift, and a pusher prop.
Pretty sure whoever designed that doesn't know anything about how aircraft fly.
It’s a fully-autonomous aircraft, and so the occupants won’t need a US FAA pilot certificate. It’s a proof-of-concept moonshot platform, but it will help refine technologies that make it eventually possible. And it’s being tested in New Zealand because of difficulties working with FAA.
Well also because there's very little air traffic to have to manage in New Zealand, aside from fellbeast and great eagles.
Given that it actually achieves flight, maybe they do. It's a different approach.
It's an interesting idea to take three simple systems and integrate them instead of a really complex system like a helicopter. I like that they're trying something different.
I think I saw a gelatinous cube in my GF's fridge. It had achieved semi-sentience and was attempting to conquer the crisper.
Attempts to make the saving throw are futile.
-an army of your allied enemies approaches
-you outnumber them 10:1
-they roll for sneak attack damage
-natural 20
-ffs
-critical hit
-roll for self destruct damage
-roll a 1
-ffs anthropomorphic eagles? What rule book are you using?
Huh? The efficiency of a pusher prop and conventional wing are significantly better than trying to use the lift rotors for forward flight. Given how limiting electrical power is, that's not surprising.
Pretty sure they know quite a lot more than you about Aircraft Design.
Distruptors only work in IT. You can't bend the laws of physics to your will just because your business is new and trendy.
Where would this be used and why? No way the FAA would approve this in the US if they haven't approved drone deliveries.
What happens when the motor fails, the battery catches fire, or the transmission fails? A multicopter can't auto rotate and if the wings are producing the lift there will be a whole lot more drag with all those stationary VTOL rotors hanging in the wind. How does it see and avoid? How does it know it's not about to land on a small child/parked car/etc. How will it factor for out of envolope W&B? How will it deal with adverse weather conditions? Looks like a whole lot of surface area to collect ice.
Of course eventually those problems will all be solved, but with today's technology if you throw the systems in that machine to handle all of those scenarios there won't be much, if any useful load/range left.
All you survey guys driving for Uber in the off season, I think your jobs are safe still.
