ClarkGriswold
Non Nutritive Cereal Varnish Engineer
FactYou two make a cute couple.
I know that that's a tongue in cheek comment. Most shops, if you break it in the sim, things won't work out well in the end.
Don't know about 121 but 135 crosswind landing technique is take an extra shot in cruise and try to hold ref + 50 over the fence.
Exactly. The airbus flight control Law will not allow a “wing down” technique.
Probably well over 90% of my landings are in a slight bank on one main gear (ala Bob Hoover). Been doing it since my private pilot days, through light twins, turboprops and an assortment of large/heavy jets.
It does take a little bit of finesse but tends to result in much smoother landings (for me at least). X-wind landings find me crabbing down final and then smoothly kicking it out in the flare and a little wing down on the upwind side. Just don’t chop the power until arresting the sink....
30 yrs of big jet flying and never a problem....
In a Lear, if it's really heavy (pushing max demonstrated XW or above), leave flaps in approach, crab to ~200AGL, then lower upwind wing with countering rudder and see if you can straighten it out. If you can, land and get the boards out most ricki tick. If you can't without lowering the wing into the pavement, go around and find another runway. Leaving flaps 20 eliminates spoilerons to assist roll at slow speeds. Spoilerons could mess up your day with a low wing situation, so you don't want them.Just got out of a sim training event. We were discussing hard landings and such, which brought up the crosswind landing subject.
Prior to today, any time I heard crosswind landings discussed, putting the upwind main down first was acceptable if it was a strong enough crosswind. No side load, rolling straight down the runway.
Instructor was of the opinion that in the 121 world, you should "be good enough" that you never make a landing on only one main gear at any time. Both mains should touch at the same time, every time. But to me that might mean a crabbed touchdown on the centerline or a straight touchdown but with sideways drift.
Thoughts?
Withhold no sacrifice, grudge no toil, seek no sordid gain, fear no foe. All will be well.
- Winston Churchill
As Rosa Parks would say, “Nah.”Exactly. The airbus flight control Law will not allow a “wing down” technique.
Whatever it takesWhatever gets the job done
(I’m not a 121 pilot)
“Honey if you call and I’m not home I’ll be at the gym or the gun club.”Whatever it takesView attachment 41916
Just to pile on, this is absolutely incorrect. You kick out the crab when you're entering the flare and apply aileron input as needed to stop drift... wing low, just like every other transport jet I've flown.![]()
I’ve heard those airbus’ go into a hold and you can’t get them out of it.
Cooperate and graduate.So, pretty much what I thought. That instructor is pretty unique in his opinion of what 121 landings should be like.
I will continue to do pilot sh*t and land the plane as it needs to land.
