Delta to announce A321neo order
Mine doesn't.
Is it common for the rest of you guys to have to add 1,000 feet to your landing distance when doing an auto land? Nothing quite as unnerving as a long float in cat 3 weather in Kazakhstan.
The A320 and MD80s don't really float from what I have seen.
I did have one that flared at 50' though. Whoops. "Click click"
Mine doesn't.
The 320 adds about 500 feet to the landing calculation for autoland. I still haven't seen a 321 QRH yet but I'd guess it's the same or slightly more.
I'm thinking that is more due to the autobraking. Max manual braking is always a lot less than medium.
Mine doesn't.
Never seen that. Unless, of course, I wasn't looking in the right place!
Paging @PeanuckleCRJ! You're probably on long call and far more convenient than my uncharged Microsoft Surface waaaaaay across the compound.
BWAHAHAHA ! ! !
Sorry. Couldn't resist that setup.
It's not related to the braking, as those differences are captured in the table data. @Derg, once you figure out a way to charge your Surface, check the in flight performance section of the QRH, assuming yours is set up the same as ours.
Is there a flight performance section of our QRH? I have no idea.
I just mash the Landing Perf button on the ACARS and go "Crap, well, we'll have to use medium brakes"
Yeah, I'm not seeing it in the QRH at all. Perhaps the ODM? Checking.
Looks like the ODM says 900 feet for dry conditions.
Ooh, and in SouthernJetsWorld, max manual braking is a shorter distance than "medium" autobrakes, but we're taught that it's not pressure, but the timing between touchdown and max automatic application.
However all manuals and operational philosophies vary from airline to airline. I remember when I was the Kung Fu Master of the MD-88 and sat in an AA Super 80 from PHX to DFW and wondered what world these guys lived in because they were doing everything absolutely wrong. :)
Yep, that’s what SJI teaches, max manual will always stop you faster and shorter than any auto brakes.
Our ODM is in our QRH, which is Airbus's way of doing it. I'd guess you guys are matching the Boeing (or MD, who knows) way and it's a separate document, for fleet commonality. As you said, every place has to reinvent the wheel in certain things.
