There are two parts to the survey. Section#1 asks what division Division of the company that you are a part of, your job title and DOH. The answer to the second section determines the end of the survey. Section #2 asks if you fly professionally. if you answer no, the survey does not go past that section. if you answer yes, it goes on to Section #3, which asks what ratings, how many hours, some other questions, and then says to contact someone in pilot recruiting. Of course I didn't get past section 2. I personally think the survey is flawed, since they want you to have a PP certificate. They're not getting viable data. They should have asked if the survey taker had a Private Pilot's certificate and those that answer yes, should be able to go on to section#3.
