Ya, this is all new to me. I have flown for 3 135s and 2 121s and have never seen such a requirement. Which is why it seems a bit absurd, but I'd also love to read your opspecs that lay this out, because I have not seen it, and most of the time they're fairly cookie cutter. C055 at a 135 multi piston shop and a 121 domestic jet shop are going to be the exact same thing.
I'd like to do me some learning and some guy on a forum said or this captain said is not really good enough.
As previously mentioned, Eaglevoy inserts the Opspec into their "FM-1". If you're able to get a hold of one, reference 6-2
Operations at Airports with no Control Tower. Here it tells you they reference Ops Specs C064, C080. Within 2.1 of Chapter 6, titled
Operational Restrictions, it explains that scheduled and nonscheduled operations are permitted at airports without a Control Tower provided the following requirements are met:
1) Instrument Approach Procedure
2) Weather
3) Airport Advisories
4) Air Traffic Advisories
Expanding on
Airport Advisories:
a) The airport must have a suitable means for pilots to acquire airport advisories. These advisories must be obtained regardless of weather conditions, for both inbound and outbound flights.
b) The advisory should include aircraft movements on or near the airport, especially traffic in the pattern. It should also include operations by surface vehicles that may be operating on the airport.
c) Airport advisories can be obtained via company personnel using the company operations frequency or through the FSS located on the field.
d) An airport advisory must be obtained by the pilots: (1) Inbound- At least 10 miles from the aiport. (2) Outbound- prior to taxi.
e) Landing is not authorized if an airport advisory cannot be obtained.
I'm now on my third airline (fourth 121 certificate) and each airline had an absurd rule that could would make me do a double take. That's just the nature of the game.
