Yes! PenAir I've been waiting for this... Wouldn't have to leave Alaska!!!!
So because Endeavour is wholly owned would you reccomendd them over Compass?Compass is owned by Trans States and flies routes for Delta and American using the E175's. Endeavor is a wholly-owned subsidiary of Delta that flies routes using the CRJ-200's and -900's.
I recommend which ever hires you. That's usually a deciding factor, and the chance of getting an offer from both at the same time I'd assume are pretty slim.So because Endeavour is wholly owned would you reccomendd them over Compass?
I didn't recommend either. I gave you the primary difference between Endeavor and Compass.So because Endeavour is wholly owned would you reccomendd them over Compass?
yes i understand your response and I appreciate it. It's just a question.I didn't recommend either. I gave you the primary difference between Endeavor and Compass.
Endeavor is a much larger operation. They are both located at the Delta facilities at MSPWhats the difference between Endevour and Compass?
Endeavor....I am a bit biased. I started at Mesaba which has been re-branded as Endeavor.
+1Does anyone have or know the payscales/CBA's for Endeavour and Compass? Or Republic?
Typical regional pay--12-15 an hour. At least you can still afford easy mac and ramen.
Compass pays better, Endeavor seems to be a better working experience.
