pianokeys
MEL NO MUFFS
Looks like a 737 on stilts.
http://www.theverge.com/2015/12/8/9872044/boeing-737-max-live-reveal-photos
I'll be in my bunk...
Correct me if I'm wrong, but the MAX would require a new type rating, would it not? I thought the contention with the 739 during development was the raising of the gear, and to avoid a new type rating, Boeing compromised with the FAA to keep it at the same height as the 738.
Those are CFM's on the Max, the NEO's are using P&W's. Close enough.Are those engines the geared ones? I didn't think the 73 could accommodate the geared engines that the NEOs are using.
Actually the -700 wasn't that loud in the JS. Didn't use headphones. FO commented on the overhead panel and its age also.Derg said:That overhead. Zzzzzzzzzzzzzzzzz. And I'll bet you it's still loud as death up front. Come on, Boeing. Innovate.
I had read somewhere recently that the Max couldn't take geared engines, is that not true?Those are CFM's on the Max, the NEO's are using P&W's. Close enough.
I haven't seen, first hand, the differences training for the NEO but rumor says the nacelles are a lot closer to the ground and FOD is a big concern.
