Assuming they departed the jet (my guess is on purpose here?), that doesn't really work. With a fully stalled wing, or even partially stalled in some cases, your ailerons aren't doing anything for you, aside from potentially making the problem worse (adverse yaw and all that)…..depending on the airframe, you might be able to do what you say with rudder/s but that can open up a whole other can of undesirable worms in a jet with a big inertia coupling tendency. Only solution is to get more airspeed over the control surfaces. Their departure wasn't this extreme, but having been in 0 airspeed or even negative airspeed/tailside departures, you are along for the ride until the stabs start working again, and a wise man still rides it out a little while longer before trying to add any roll inputs, lest you depart again.
