Hacker15e
Who am I? Where are my pants?
The second crewmember was nice
Sure made packing the travel pods easier.
That's kind of what I'm getting at. This sounds like a lot of work compared to what I have flying single pilot in my 36 year old turboprop.
constantly making one click of the trim up.....and one click down......and one up.....etc...to get it to stay level.
Says a man that thinks pilots are dangerous, military or otherwise. because the airplane won't fly itself. How did you ever obtain a PPL and instrument rating without perhaps sweating a bit and actually flying, safety be damned. Once again your arrogant opinion belittles anyone who is not an airline pilot and proves you've forgotten your origins. Unless you did all of your initial training in an aircraft that was somehow superior to what your Captain learned in your opinions are likely to fall on deaf ears. No one ever called you Captain with any sincerity, and your mooney passengers don't count you truffle eating omnivore.Man, that sucks.
Have you seen the discussion over on baseops on this topic? Definitely a different perspective then on here.
Not a surprise...as I posted earlier, there is a lot of ignorant bluster all sides of the conversation, mostly due to ignorance on one side about the other side.
What autopilot?
I suspect the NTSB is going to talk about multiple causes (not fault; "fault" is for the FAA, the courts, and online forums where people like to yell at each other) and safety recommendations. I won't speculate but I can easily see a combination of factors involving all three participants that led to the event.Exactly plus when IFR ATC must provide separation. I don't know how the view is out the F-16 but the Cessna could have been completely hidden from the pilots view...
Going to be an interesting one to follow to see where the NTSB goes with it.
I don't want aircraft calling me prior to their departure.The replay I've seen had an altitude indicated for the C150. I just don't understand why aircraft don't call approach prior to departure if you're going to be in the vicinity of another airport or possible busy final.
Separation services depend on both airspace and communication. That's pretty basic.I'm still curious on the ATC side of the house- is the controller not responsible for separation of IFR from VFR traffic? How is this not a "deal" for them?
What Mark said above. Separation services are required in Class C, Class B, and TRSA. Traffic advisories and safety alerts are the standard pretty much everywhere else. Now, you might consider a safety alert a form of separation, in that the controller should issue a suggested heading on two targets getting in dangerously close proximity, but in the real world with the VFR target not talking to you and a load of traffic on the radar display it's possible to miss a sudden convergence when the uncontrolled VFR abruptly changes heading. If the equipment your using has Mode C Intruder software you'll catch it when the alarm goes off and usually with enough time to take corrective action, but if the VFR doesn't have Mode C that software is pretty worthless.
Right- but unless I'm missing something in the transcript, wasn't the F-16 on radar vectors? Since the VFR traffic was reporting position and altitude, how does an IFR aircraft on a clearance get vectored into a squawking target?
